Opinions on my current home network setup?
Discussion in 'Networking, Telephony & Internet' started by the_antipop, Aug 8, 2019.
  1. the_antipop
    the_antipop Member
    Jun 11, 2005
    1,792
    Gold Coast
    Hey all,
    Wasn't quite sure where to post this, so thought here would be okay. I just thought I would pick your brains a bit and see what you thought of my current network setup at home.
    There are also plenty of Wireless devices running off the Telstra Smart Modem - phones, laptops, printer etc.
    Is there anything that I should do to improve connectivity? Are there downsides to the "cheapish" 5 port gigabit switches?
    Thanks for any advice
    Pugs likes this.
  2. caspian
    caspian Member
    Mar 11, 2002
    10,262
    I see no issues with it. if it's doing everything you want it to, there is no reason to change anything. it's a simple network, no need to overthink it.
    Pugs, the_antipop and Nobby6 like this.
  3. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,230
    Not enough devices connected to the network to be an issue. Just don't connect another switch to the existing switches :p
  4. Copie
    Copie Member
    Jul 24, 2009
    13,618
    Newcastle
    Piss off that telstra shithouse 'modem' get some unifi gear.
  5. dimension11
    dimension11 Member
    Mar 16, 2016
    47
    The main thing is if it's working for you.
    iperf3 is a great tool that lets you test the speed and if everything is mostly getting full speeds then you're good.
    The potential bottleneck would at the Telstra modem point, if you're sending large amounts of data Eg. streaming multiple shows from the NAS to each of the devices on the right.
    Would highly recommend pfSense if you're in the new market for new gear, they make appliances or you can install it on an old PC to test. If you're after a cheaper the Edge Router X by Ubiquiti is a good option
