Pablo's Powershell Pow-Wow
Discussion in 'Business & Enterprise Computing' started by PabloEscobar, Sep 18, 2014.
  1. looktall
    Sep 17, 2001
    26,649
    That what I've been working on for where I work.
    A script to onboard and a script to exit.
  2. freaky_beeky
    freaky_beeky Member
    Dec 2, 2004
    1,169
  3. looktall
    Sep 17, 2001
    26,649
    I'd be staggered if they did.
    But I'll check that link out anyway because I know IT management is keen to hand off account creation to HR.
  4. freaky_beeky
    freaky_beeky Member
    Dec 2, 2004
    1,169
    Right where it belongs.
    If you've got RBAC configured you could create a table of Role to Group Membership mappings, and then any access issues are also all HRs problem.
    randomman likes this.
  5. sic_vl2000
    sic_vl2000 Member
    Dec 13, 2004
    991
    Are you able to share what your script looks like at all?
  6. sic_vl2000
    sic_vl2000 Member
    Dec 13, 2004
    991
    Has anyone used a script to logoff disconnected sessions from Citrix app centre?
  7. karmic
    karmic Member
    129
    Whats the use case here? Normally you would have GPO's managing both idle the time before disconnecting a users session, and how long before a disconnected session is logged off.
  8. sic_vl2000
    sic_vl2000 Member
    Dec 13, 2004
    991
    It's part of the calls that support desk get at the moment from staff while wfh. If someone's connection drops out then their session gets cleared and they can login again. Probably get around 10-15 a day on average.
  9. richard0296
    richard0296 Member
    Jul 28, 2009
    2,565
    sydney
    would powershell really add any efficiency vs having director/app centre open each morning? if 7 and > i've had good experiences with ctx ps broker cmdlets and get-brokersession/disconnect-brokersession -username -sessionstate etc however i still don't see this adding any benefit unless you are trying to take service desk/help desk out of the equation and just straight up disconnecting all stale sessions on an X minutes basis
  10. miicah
    miicah Member
    Jun 3, 2010
    7,454
    Mount Cotton, QLD
    Code:
    Get-ADComputer WS123456789 | Select -ExpandProperty DistinguishedName.Split(",")
    Get-ADComputer WS123456789 | Select -ExpandProperty DistinguishedName {$_.split(",")}
    Trying to get a specific OU out of the DistinguishedName, how the hell do I do this in a one liner? Managed to get it to work by doing it this way:
    Code:
    $fullOU = Get-ADComputer WS123456789 | Select DistinguishedName
    $splitOU = $fullOU.DistinguishedName.Split(",")
    $splitOU[1]
    But surely there is a clean way to do this in one line?
    EDIT: Got it :)
    Code:
    Get-ADComputer $computer | Select {$_.DistinguishedName.Split(",")[1]}
    colmaz likes this.
  11. gav1ski
    gav1ski Member
    Aug 9, 2001
    161
    You could also try a combination of indexof and substring to pull it out if you don't want to use an array position
  12. miicah
    miicah Member
    Jun 3, 2010
    7,454
    Mount Cotton, QLD
    I suspect this is a sort of "do it how you want" type of thing, but is there any general layout or way to get something like this done in a script?
    Code:
    $envVariables = Get-CimInstance -ClassName Win32_Environment
    $usrGroups = ($envVariables | Where-Object {$_.Name -eq 'USERGROUPS'}).VariableValue
    Like there are a few ways I can think of doing this, but is there a more correct way?
    PabloEscobar
    PabloEscobar Member
    Jan 28, 2008
    14,621
    https://xyproblem.info/ :).
    What are you actually trying to do?
    looktall likes this.
  14. miicah
    miicah Member
    Jun 3, 2010
    7,454
    Mount Cotton, QLD
    I want to run certain PowerShell functions based on the logging in users OU, the computer OU as well as the groups that a user is a member of.
    Our login script (which is a VBS script written by the department and applied state-wide, I cannot modify it) writes the environment variables to the registry on login. Through testing I have found that when a user logs on to the device for the first time, using the PowerShell $env: drive pulls up some generic environment variables and not the custom ones written to the registry (side note, they work fine on second login).
    So I found the Get-CimInstance command, used that and pulled the data, it works.
    It returns an object of Microsoft.Management.Infrastructure.CimInstance#root/cimv2/Win32_Environment, with 3 columns and I figured out a way of returning certain values based on the 'Name' property as above.
    I was just wondering if there is a more correct way to do this in a written script, vs a one-liner in a PowerShell window.
  15. randomman
    randomman Member
    Oct 21, 2007
    5,138
    Vancouver, BC
    No need for select, just call the property directly
    miicah likes this.
  16. Ogre
    Ogre Member
    Aug 13, 2003
    2,447
    Sydney, Australia
    So the end goal is to have two login scripts?
    If the variables you want are written to the registry why not pull from there or if they are based on Active Directory, just pull directly from Active Directory?
  17. miicah
    miicah Member
    Jun 3, 2010
    7,454
    Mount Cotton, QLD
    Yes essentially, since the department is dragging their feet on changing the logon.vbs over to PowerShell. So in their script I am able to add a line to call my own PowerShell script.
    I am pulling from the registry, it works as I expected, I'm just wondering if there are conventions for writing script blocks over one-liners, or if it's "if it works it works" kinda thing.
  18. Ogre
    Ogre Member
    Aug 13, 2003
    2,447
    Sydney, Australia
    Something like this might help https://github.com/PoshCode/PowerShellPracticeAndStyle
    Think commenting, readability, logging and error handling
    miicah likes this.
    PabloEscobar
    PabloEscobar Member
    Jan 28, 2008
    14,621
    For me and mine.
    Anything that is going to live longer than the PS Session its in, won't use Aliases or one-liners
    Readability and supportability are king when it comes time for future me to look at how/why something is being done.
  20. leighr
    leighr Member
    Feb 28, 2002
    600
    Richmond, Melbourne
    More often than not, past me is an absolute arsehole. :Paranoid:
