PC for photo editing
Discussion in 'Graphic Design & Digital Art' started by breno, Oct 27, 2021.
  1. breno
    breno Member
    May 3, 2011
    1,886
    Hi all,
    Hope this is the right place for this specific question. I'm looking to build a PC for a friend specifically for photo editing (PS and LR). Not the best budget but i'm looking at putting in a R5 5600G, would there any benefit to adding a GT1030 for PS to render using CUDA cores? Or would there not be much benefit worth the extra $120?
  2. theSeekerr
    theSeekerr Member
    Jan 19, 2010
    3,712
    Broadview SA
    breno likes this.
    breno
    breno Member
    May 3, 2011
    1,886
    Ahh that's what I was looking for. Thanks for the link.
    If there would be any 'benefit' would be having the VRAM so not having to share system memory. I am going for 16GB RAM, don't think they would need 32GB with the work they're doing...
  4. Slug69
    Slug69 Member
    Aug 28, 2002
    10,138
    Apple macbook air?
  5. Admiral
    Admiral Member
    Jun 30, 2001
    2,070
    Sydney, Australia
    You'd be amazed at how quickly Photoshop can eat RAM - especially once you start getting into large, multi-layered documents. If the edits are rather simple processes within Camera RAW or Lightroom, then 16 will probably get you there, but if your friend wants to try any compositing then making the leap to 32 will help. Aside from that, having a speedy SSD set as your scratch disk also helps once the RAM fills up.
