Pc not booting, suspect cpu
Discussion in 'Troubleshooting Help' started by Nitro_123, Apr 11, 2020.
  1. demiurge3141
    demiurge3141 Member
    Aug 19, 2005
    1,985
    Melbourne 3073
    Could just use metho.
  2. Deus_Ex_Machina
    Deus_Ex_Machina Member
    Jun 6, 2007
    461
    Geelong VIC
    I personally wouldn't use metho as it's a bit of an unknown as to what is added to the ethanol other than methanol. Can have MEK, acetone and other shit in it. Might be OK but might not.
    Pure (well as pure as you can get) IPA is the go. I have submerged entire smartphones in it and resurrected from water damage without damaging any components. I'm like that dud in my big fat greek wedding with his Windex. It goes on everything !!!!!!! Well it used to, now I use my last litre as liquid gold :)
    adamsleath likes this.
  3. jekel
    jekel Member
    Jul 24, 2004
    523
    Bad luck, in 23 years I've only had a I think a i7-930 becoming a bid dodgy but pretty sure was from me overclocking it hard and then last year my 4690k fully died and motherboard showed cpu error light. The 4690k was a surprise as I only had a mild overclock on it but ow well 5 years use so felt like I got my money out of it.
  4. adamsleath
    adamsleath Member
    Oct 17, 2006
    18,371
    Sunnybank Q4109
  5. Recharge
    Recharge Member
    Sep 5, 2001
    11,314
  6. adamsleath
    adamsleath Member
    Oct 17, 2006
    18,371
    Sunnybank Q4109
    i suppose it might clean some socket contact points that may have become grimed up or something....ie bad contacts that are friction-fit type.
    Nitro_123
    Nitro_123 Member
    Feb 9, 2019
    10
    I have isopropyl alcohol from Bunnings, might give that a shot with a toothbrush. I can't comprehend how dust and stuff could get into a closed socket with a heatsink on top, but then again my PC randomly stopped working so who am I to assume
  8. Deus_Ex_Machina
    Jun 6, 2007
    461
    Geelong VIC
    It's bloody unlikely honestly but worth a go. My days of testing defied logic and eventually when I saw what looked like bent pins (oddly reflected light) but the pins weren't bent I gave it a clean. I assume it was paste but was very small. Was blown away when it fired up straight away. It had actually worked for about 2 weeks before this happened so must have JUST moved into the wrong spot.
    terroristone likes this.
    Nitro_123
    Nitro_123 Member
    Feb 9, 2019
    10
    Hey everyone, thanks for all the advice. I did try the ISO trick as well, didn't work sadly.
    I bought a replacement CPU and everything instantly worked just fine. Thanks for all the advice!
  10. adamsleath
    adamsleath Member
    Oct 17, 2006
    18,371
    Sunnybank Q4109
    interesting. glad you sorted it.
    Nitro_123 likes this.
  11. ShaggyMoose
    ShaggyMoose Member
    Jul 1, 2002
    459
    Did you RMA the faulty CPU?
    Nitro_123
    Nitro_123 Member
    Feb 9, 2019
    10
    Yes I did, still in RMA. That reminds me, I should email them
