PCI-E Extenders
Discussion in 'Modding' started by SpaceFrog, Jul 24, 2020.
  1. SpaceFrog
    SpaceFrog Member
    May 29, 2002
    2,180
    Brunswick, Melb.
    Hi Guys, getting bored and trying to think of crazy projects.
    Would like to get an NVME drive in my main rig. There are no M2 Slots, only an MSATA. There are 2 PCI-E x16 slots that are next to each other, and if you see in the photo the spare slot is covered by an RTX 2060 fan shroud.
    can anyone recommend me a suitable X4 extender that would allow it to plug into the spare slot, and route the cable around the graphics card to allow enough room for a PCI-E X4 -> M2 adapter
    Ideally the extender contacts would be hard 90 degrees, it seems the contacts are nowhere near flush and will hit the fan shroud. I could probably remove the shroud or cut it, but would prefer not to
    Does anyone know If I can set an NVME as boot drive on an 79R chipset?
  2. Samicans
    Samicans Member
    Mar 22, 2020
    46
    SA
    MattyCC83 likes this.
  3. MattyCC83
    MattyCC83 Member
    Feb 4, 2020
    6
    Perth, WAAA
    Any more pics of this machine? sweet little SFF rig by the looks
  4. Renza
    Renza Member
    Dec 1, 2004
    4,948
    You can inject the nvme module into EFI, I did it on my z77 board and can boot natively from my Samsung 970 evo plus.
    alternatively, if you get a Samsung 950 Pro, they have an option ROM so you can boot from that with CSM on any board
    OP if you need a modded bios, happy to lend a hand
    edit: looks like a shuttle system?
    SpaceFrog
    SpaceFrog Member
    May 29, 2002
    2,180
    Brunswick, Melb.
    Yep it's a Shuttle SX79R5. Interesting to know about the 950 PRO.
    Not sure If I want to mess with the BIOS, I've had a few issues with the machine not starting up. Often happens if I lose power while in standby. Unless someone has a custom bios that increases stability then I'll leave it alone.
