PCIe device randomly starts/does not start
Discussion in 'Troubleshooting Help' started by Automaton, Mar 31, 2013.
  1. Automaton
    Automaton Member
    Mar 28, 2007
    118
    Recently did a fresh OS install of my current rig and the wi-fi card I've got is playing up (Abit Airpace).
    It's in the PCIe x1 slot and it seems that every 2nd time I boot the machine up no device is detected in that slot, even in hardware manager. If it's not detected, a reset will usually make it re-appear.
    Am trying to hunt down some other drivers (it's based on an Atheros chipset) but was curious if anyone knows what a likely cause for such a problem is? It's obviously not completely faulty.
    Thanks a bunch.
  2. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,766
    ADL/SA The Monopoly State
    Try giving all the contacts a clean, also bend the bracket a bit so the contacts slide deeper into the slot if possible.
    Turn off pcie link power mangement in your power settings.
  3. GRH
    GRH Member
    Dec 29, 2011
    229
    reseat & clean as suggested above.
    try a different slot if possible
    on a note
    pci &pcie wi-fi cards are the most commonly failing components i have come across.. so dont be surprised if thats the case.
