Pepsi Max = Fattening or Not?
Discussion in 'Geek Food' started by cybermatic, Oct 10, 2004.
  1. cybermatic
    cybermatic Member
    Jun 26, 2001
    1,165
    I know fizzy drink on the whole isn't good for your teeth or your body in general. Unfortunately, I drink alot of Pepsi Max. On average I drink about 2 litres a day. This I know can't be good for me or anyone for that matter but I am not worried about whether or not it is good for me. What I want to know is whether or not it is fattening (such as a block of chocolate is).
    On the bottle is says it contains 'no' fat, 'no' sugar, infact.. it doesn't seem to contain anything at all but a small amount of sodium (from memory) which brings me to the conclusion it isn't fattening - it is basically just water with some flavouring.
    That said, does that mean someone could drink as much Pepsi Max as they want and never put on weight because of it?
    :confused:
  2. Parthi
    Parthi Member
    Apr 7, 2004
    222
    depends how much energy in it (calories). if there is lots of energy in it and you dont use the energy its fattening
  3. marttim_00
    marttim_00 Member
    Apr 7, 2003
    404
    Gold Coast
    pffft 1 - 2 litres.... try 34 cans of coke in 1 day
  4. Defsac
    Defsac Member
    Aug 6, 2003
    939
    Diet colas use aspartame as a sugar substitute. Since aspartame has no nutritional value, your body can not store energy from it, meaning you won't get fat from the aspartame itself. There may be other substances in the drink your body can use (water for example), so it could be possible to gain weight if this was so. From memory, Pepsi Max contains no energy at all so the short answer to your question is no.
    Keep in mind aspartame has component chemicals which are rather nasty (methanol, formaldehyde and formic acid) so if you insist on drinking the stuff, try to get batches as fresh as possible to minimize the risk of it breaking down into it's components.
    Edit: added more info
  5. GooSE
    GooSE New Member
    Jun 26, 2001
    6,679
    i.e. No, it's not fattening. But I don't think it would be doing great things for other aspects of your health either.
  6. pyrox
    pyrox Member
    Apr 23, 2004
    697
  7. Dan!el
    Dan!el Member
    Dec 24, 2001
    2,945
    I thought it broke down into phenylalanine, aspartic acid (two amini acids!) and methanol. :confused:
    EDIT: Ah.. the Methanol is broken down into formaldehyde which then quickly breaks down into formic acid - which you apparently have 20 times this amount that is in a can of pepsi max in your average daily diet anyway.
  8. Narusagewa
    Narusagewa Member
    Jun 22, 2003
    760
    I find drinking a lot of soft drink subdues my hunger. Like I needed to lose 3kg in a week, I just had coke for 2 meals a day and then some food the third one, lost it easy.
    Probably health problems but meh.
    BTW I'm not fat...
  9. zeddyzapper
    zeddyzapper Member
    Dec 23, 2001
    309
    Humm,
    used to drink heaps many years back,, now guts is rejecting most foods :(
  10. Protius-X
    Protius-X Member
    Nov 29, 2003
    403
    Redcliffe 30mins North of Brisbane!
    It has extra caffien(sp?) compared to normal pepsi to replace the sugar.
    EDIT: If I can remember correctly
  11. SyN
    SyN Member
    7,279
    ouch!
    but thanks for that, im a bit repelled from soft drinks for now
  12. BLAZEUP420
    BLAZEUP420 Member
    Jul 3, 2004
    1,119
    the moon
    getting fat should be the least of your worries
    god damn man drink some water
  13. zztopless
    zztopless Member
    Feb 6, 2002
    225
    what's the difference between Pepsi Max and Diet Pepsi?
  14. BLAZEUP420
    BLAZEUP420 Member
    Jul 3, 2004
    1,119
    the moon
    pepsi max is EXTREME!!!!!!!
    i think that's about it
  15. Romen
    Romen Member
    Mar 14, 2003
    2,582
    Adelaide, SA
    Caffine is the difference
  16. samos
    samos Member
    8,564
    There's no conclusive evidence on the effects of aspartame, but I wouldn't trust it. Some say in copious amounts it has caused brain tumours etc.
    I use the sugar "equal" which contains whatever amount in it. I don't have much aspartame at all really, I don't even drink diet coke or pepsi max (rarely anyway). 2 Litres is far too much imo. I'd be keeping well hydrated with water, as from memory I think it is diuretic.
    As for the consequences, well you may see them short term or long term, but I'd keep it to a minimum for healths sake.
    As for fattening, no. There's pretty much no KJ in it at all.
    cybermatic
    cybermatic Member
    Jun 26, 2001
    1,165
    That is a little worrying! If that is the case, I think getting fat is the least of my problems.
  18. Vow
    Vow Member
    Aug 23, 2001
    629
    It's broken down in your body, so the age of batch has nothing to do with it.
  19. Defsac
    Defsac Member
    Aug 6, 2003
    939
    Your body won't break down aspartame into diketopirerazine, however prolonged storage will. Diketopirerazine is arguably the most damaging compound found in aspartame, being linked to brain tumors and blood cholesterol changes.
  20. Xplora
    Xplora Member
    May 24, 2002
    7,003
    The worst part about P Max is the acid... and yes the caffeine can become extremely addictive!
    The distortions in your diet from the caffeine intake could cause more problems than they fix.
