Photoshop Help
Discussion in 'Programming & Software Development' started by biatch, Aug 12, 2002.
  1. biatch
    biatch Member
    Jun 18, 2002
    1,719
    North Brisbane
    I generally use fireworks, i've never touched photoshop because it looks so damn complex!
    but even with fireworks i only do very very very basic sort of stuff..
    i was after some help with how you get some really cool looking graphics in photoshop and fireworks, if it does what i'm after!
    the sorts of things you find on winamp skins ..
    for instance
    links? tutorials? help?
    heh
    thanks!
  2. NHD
    NHD Member
    Jul 9, 2001
    936
  3. Wizardx8
    Wizardx8 Member
    Jan 2, 2002
    2,742
    Singapore
    I have found a magnificent site for interface design in photoshop is Eyeball Design
  4. thetron
    thetron Member
    Dec 23, 2001
    8,167
    Somewhere over the Rainbo
    it's one of the site they used in reference sites in one of the muiltmedia classes i did back in 2000
    where we had to make-up a interface, i ended up leave cause it was affecting my normal school work
    although the site design is getting old (eyeball design site)
  5. thetron
    thetron Member
    Dec 23, 2001
    8,167
    btw those ain't winamp skins
    i think their sonique skins cause i am not sure winamp is limited to square interfaces
  6. NHD
    NHD Member
    Jul 9, 2001
    936
    winamp 3 i think allows you to skin in any shape
  7. thetron
    thetron Member
    Dec 23, 2001
    8,167
    also winamp 3, i find it can be unstable in my uses of it
    biatch
    biatch Member
    Jun 18, 2002
    1,719
    North Brisbane
    they're definately winamp skins, i got them from the winamp3 skinning forum ...
  9. thetron
    thetron Member
    Dec 23, 2001
    8,167
    okie dokie
    i suggest you mask out a design and start from there dude
  10. Evasive
    Evasive Member
    Mar 22, 2002
    375
    Do ya come from a Land Down Under...
    This link:
    http://www.3dcafe.com/asp/tutphotoshop.asp
    will help you to do those interfaces. Believe it or not, they're not difficult to do.
    I think Da Man of this forum and the bloke to ask all these 'Shop questions at is Whitney Ford. I could help you out, being a graphics semi-professional myself, but unlike Mike, I can't be arsed :D
    Cheers,
    E
  11. RioT'uS
    RioT'uS Member
    Jul 3, 2001
    442
    Is there a gradient mesh tool in photoshop? I've never tried to do stuff like that with it. We are learning Illustrator at uni atm and have been using the gradient mesh a lot to make stuff look 3d like that.
  12. coolmach!ne
    coolmach!ne Member
    Aug 9, 2002
    13
    Yep.
    It's far better and quicker to design things like that in Adobe Illustrator, and then move it into photoshop for the final touches and finishing effects
