[PHP] Problems with function using strrpos() and substr(), plz help...
Discussion in 'Programming & Software Development' started by SpeedFreak, Jul 26, 2003.
  1. SpeedFreak
    SpeedFreak Member
    1,385
    London, UK | OCAU's Euro corrispondant!
    hey,
    i have this code:
    code:--------------------------------------------------------------------------------
    if (preg_match("#<!--INTRO-->#", $row['post']))
    $istart = strrpos($row['post'] , '<!--INTRO-->' ); //position of intro
    $isend = strrpos($row['post'] , '<!--END-INTRO-->' ); //position of end intro
    $iend = $isend-$istart; //difference integer
    $extract = substr($row['post'], $istart, $iend);
    else {
    $extract = $row['post'];
    the else{} part works fine but the substr() bit doesnt as $extract is being returned empty when the preg_match statement returns true.
    what have i done wrong?
    Cheers
  2. Gumby
    Gumby Member
    1,743
    echo some error checking lines.
    ensure that its getting $istart and $isend properly, and that its calculating $iend.
    SpeedFreak
    SpeedFreak Member
    1,385
    so just echo each variable as the script goes on to check if its recieving it right?
    i'll give it a go :)
  4. Bangers
    Bangers Member
    Dec 25, 2001
    7,254
    Silicon Valley
    Give $istart, $iend static numbers to see if they are causing the problem. My guess is that they are, but I wouldn't touch PHP with a 40ft pole so I'm sure.
    My guess is that both $istart, $iend are 0. Echo those variables out.
    SpeedFreak
    SpeedFreak Member
    1,385
    fixed :)
    i was using strrpos() which only allows a single character as the needle :rolleyes: D'oh!
    i needed to use strpos(), except a mate of mine showed me a more efficient way of doing it like so:
    PHP:
    if (preg_match("/(.*)($start)(.*)($end)(.*)/i"$row['post'], $yourtext)) {
    $extract $yourtext[3];
    $extra "...<br><br><font size='2' face='verdana'><b><a href='" $ibforums->base_url "?act=ST&f={$row['forum_id']}&t={$row['tid']}'>[Read the Full Article...]</a></b></font>";
            else {
    $extract $row['post'];
    $extra "";
    All this was part of a mod i was writing for Invision Board ssi.php to get more control over news exporting with a defined intro and full article section. I modded the post parser aswell to tell it to turn [intro] tags into <!--INTRO--> and <!--END-INTRO-->. This has no effect in the forums, but the ssi.php file extracts only the intro (if it exists).
    The fruit of this can be seen on my latest creation: www.ps2evolution.com
    thanks to all who helped :)
    (this mod is prolly gonna be included in the next release of invision)
    Cheers
