Plantronics Callcentre Headset
Discussion in 'PC Audio' started by finkinovu, Apr 26, 2012.
  1. finkinovu
    finkinovu Member
    Sep 9, 2006
    5
    Hey everyone.
    Just wanted to get some advice on using a Plantronics Supra callcentre headset from an old job I had years ago.
    At the moment is has the Plantronics QuickDisconnect to RJ45 cable.
    I've done some research and found you can get a Quick Disconnect to USB cable instead.
    Quick Disconnect plugs: http://goo.gl/Veksj
    Quick Disconnect to USB adapter: http://goo.gl/wdN2C
    Was wondering if anyone's used this option as a VOIP headset for likes of Skype or TeamSpeak etc? Drivers required etc?
    Any answers or tips greatly appreciate it.
    Cheers.
  2. garetz
    garetz Member
    Aug 7, 2002
    896
    2217
    I have one of those Quick Disconnect to USB adapter without the control part, couldnt get it to work.
    It definitely requires drivers. Couldn't find them.
