REVIEW Plasma Cutting "updated 4/5/15"
Discussion in 'Hobby Engineering' started by Mathuisella, Mar 31, 2015.
  1. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    6,592
    in your gearbox...grindin
    well, today after many weeks of waiting my Cut-50 plasma cutter arrived.
    Sorry to say, but I won't have any time to do a review/demo of the uni until the weekend at the earliest, so this is just a teaser as i have yet to even open the box
    Update. Unpacking and thoughts before use.
    Quite nicely packed, i must say I've seen quite worse.
    Front view
    Rear View of the unit
    Close up of the pressure gauge, which is sorta handy to be on the front.
    rest of the contents
    The pressure regulator
    Spare consumable pieces, these seem to be fairly nice pieces, nickel plated unlike other cheap ones that are bare copper.
    The torch with a preinstalled ( came like this) set of consumables installed
    Regulator in hand. seems to be semi fragile.
    the manual isn't too bad at all, simplified with inages that are helpful for those who haven't set one of these up before, and with little "chinese-english" ;)
    how the air regulator is supposed to look, however, you will need to supply your own 'plumbers tape'
    Needed to replace the inlet with a compression fitting that would connect to the compressors hose
    Quite a hefty power cable is on the unit, 15Amps, although with all chinese made stuff, i don't take it as gospel so to speak. Note: the "earth" is damn big and will have a difficult time fitting in a lot of sockets.
    Just a little something from the manual to help
    update:
    4/5/2015
    https://www.youtube.com/watch?v=omRwXQtQr-0
    First time cutting 1/2 inch steel. need the 15amp outlet, on a 10 amp outlet i'm good for up to 25 Amps, can trip on 30 Amps
  2. iNoob
    iNoob Member
    Jul 18, 2009
    4,767
    9/11 review :thumbup:
  3. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,621
    you're going to mount this onto an x/y carriage for automating/perfecting your cuts right? :leet:
    Mathuisella
    Mathuisella Member
    Dec 3, 2002
    6,592
    use it to cut the pieces to make the cnc portion ;) i like that idea.....
    make it removable of course so you can use it for oddly shaped pieces, or ones that aren't able to be table mounted.
  5. mtma
    mtma Member
    Aug 12, 2009
    4,801
    Ah plasma cutters.
    Do some practice cuts on some 25mm plate;
    Realise you've cut a face 50mm deep in the concrete of the shed :lol:
  6. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,621
    LOL pics please! :lol:
  7. eddahenry
    eddahenry Member
    Mar 26, 2015
    32
    The most important thing with plasma is very clean very dry air ,
    Filter and water trap on your compressor , filbert and water trap on the machine , make sure you drain you compressor tank.
    If not it Will eat consumables like I eat spring rolls at a Chinese all you can eat
  8. duong01
    duong01 Member
    Mar 7, 2011
    97
    noble park
    get a HF start torch instead of a pilot arc one it'll save you the tears :D
    Mathuisella
    Mathuisella Member
    Dec 3, 2002
    6,592
    Updated first post. yet to use.
  10. cdtoaster
    cdtoaster Member
    Jan 21, 2007
    4,695
    Tokara forest
    you should call it Dr Cutso
  11. Anakist
    Anakist Member
    May 15, 2003
    2,627
    Rockhampton CQ
    Clean dry air as said!! It is amazing how much air they actually use too. Make sure your compressor is up to it!
    Get a toilet paper filter on the machine end after your water trap / regulator. Makes a huge difference to longevity of parts. We had to use TP filters on all our hire machines or the morons using it out in the boonies complained about "shitty torches' running them straight off an unfiltered compressor.
    James
    Mathuisella
    Mathuisella Member
    Dec 3, 2002
    6,592
    good tip.
    I have a 2.5 horse power air compressor with a 40 litre tank. doing pretty well with it.
    I've been using it to make a custom one off jewellerybox for the other half. :) Not the best work, but still think she'll love it. "crosses fingers"
  13. patto
    patto Member
    Feb 25, 2002
    7,131
    You know that is by design right??? The earth is meant to be big to stop you putting it in a regular 10A socket.
    Mathuisella
    Mathuisella Member
    Dec 3, 2002
    6,592
    ah, good to know :) well she's working fine although trips the powerboards circuit on occasion, but that's ok as i just let the compressor catch up/refill and stretch out my hand/arm to avoid RSI :) :thumbup:
  15. ShadowBurger
    ShadowBurger Member
    Feb 19, 2008
    1,621
    lol.. did you just dremel the socket a touch? :lol:
    Mathuisella
    Mathuisella Member
    Dec 3, 2002
    6,592
    no, just pushed it in >.<
    I was using one of those outdoor 20m long extensions with the reel. The reel with the 2 port on it, is made from plastic that can take a beating i guess :)
  17. kombiman
    kombiman Dis-Member
    Dec 3, 2006
    11,724
    viva brisvegas
    A long extension lead will also increase the chances of a circuit blowing. Nice work Math, keen to see how well it works. Do you have a water trap on your compressor?
    Mathuisella
    Mathuisella Member
    Dec 3, 2002
    6,592
    unsure. I do know that the bottom port on the compressors tank has a tiny leak, so i need to redo the tape on the valve or put on a new valve tap. But have considered it to be the 'water escape :D
    I've cut some pieces with it and it seems to do pretty well. the real test will be when i try to cut some 8/10mm thick steel :)
    in regards to the extension lead, yeah there's more resistance and thus higher current needed to get the 'power' through and thus a vicious cycle, but can't do much about that as the unit has a short power lead and have to do the work outside :(
    I'm happy to just have 'breaks' every now and then when the powerboard's trip cuts out the power on occasion :)
  19. NanoDuke
    NanoDuke Member
    Feb 4, 2007
    7,306
    What he meant was in relation to this:
    The ground pin is larger because it's a 15A source. It's designed that way so that muppets don't go putting it into a standard domestic 10A socket.
    That's what Shadow meant, it should not fit in a standard socket, and suggested that you used a dremel to open up your socket to fit.
    Seriously look at getting an electrician in to fitting you out a proper 15A outlet. Last thing you want is something catching fire. Or your powerboard trip to fail and it takes out the circuit in your wall.
    Also if you're using a long extension lead, make sure you unwind it before using it. Especially with this beast. The coils will induce a magnetic field which can heat up = more resistance = tripped circuits.
    Mathuisella
    Mathuisella Member
    Dec 3, 2002
    6,592
    cheers :thumbup:
    I'll put a power meter onto it next time i use it and see how much current it draws :) then go from there :) :thumbup:
