PlayerUnknown's Battlegrounds
Discussion in 'PC Games' started by BuZeR, Mar 18, 2017.
  1. defecat0r
    defecat0r Member
    Oct 20, 2002
    136
    Ipswich
    I actually think that's North America. I'm using Outfox to lower the latency a bit, and it shows the region the server is located in.
    SEA seems to get ~150-180 for me, Singapore is best at ~130ms. North America is all that pops these days, FPP solo and FPP duo with 230-250ms.
    I still want to play but this latency can only be described as unplayable. Might have to pick battlefield up, tho it's not going to be the same :(
  2. Benno1988
    Benno1988 Member
    Oct 30, 2007
    5,318
    You been playing it on faceit? Good?
    Should give it a crack.
  3. iinsom
    iinsom Member
    Jun 6, 2007
    5,868
    The Riff
    It could be NA as well. I can tell when i get an NA server cause its between 280-340 ping. Others are between 150-200. Ive been using Wtfast VPN, only one thats worked for me thus far. Everygame has been below 200ms (which is still too high) and the odd game at 100 (which is bearable) However if you want OCE ping, queue Faceit. You can queue solo and they'll put you in a team with other solos or duos to make a 4 man squad (they only have squads currently since the playerbase isnt big enough for solos and duos as well)
    The standard of player is alot higher in Faceit then pubs. Especially now we always get SEA servers (where the player quality isnt as good)
  4. chewbacca
    chewbacca Member
    954
    Snow map is now available on Pubg test servers! 15GB download though. Ouch for those without decent NBN.
  5. s4mmy
    s4mmy Member
    May 20, 2004
    2,211
    I played a few rounds of it over the weekend. I really enjoyed it. A few bugs for them to fix in it but nothing surprising really.
    Hopefully everyone enjoys it.
  6. Benno1988
    Benno1988 Member
    Oct 30, 2007
    5,318
    I logged on in peak time and it stuck me on a 300ms ping server. Quit and played something else.
  7. kbekus
    kbekus Member
    Aug 28, 2001
    1,220
    Pascoe Vale, Melbourne
    yeah only squad seems to get you a Sydney server, and then only TPP too.... and then not always... a couple of times yesterday around 2ish in the arvo our squad found ourselves on a 280ms ping server.
  8. s4mmy
    s4mmy Member
    May 20, 2004
    2,211
    Weird... I was getting 180-200 games. Managed to win a couple too.
  9. Bourke
    Bourke Member
    Jun 29, 2017
    465
    new rig
    9600k+32gb of ram +15gb of pagefiles + 970 pro 500gb NVME SSD + 1080p @144hz
    Had to use a gtx 680 coz 1080ti is dodgey for some reason.
    capped at 100fps, low was 42fps, high was 71fps, gpu at 100% but temps were 65'c
    9gb in ram used and 9gb of pagefiles used.....which is a hell of a lot of resources.
    Game played perfect, 1min waits per game, no stutter or frame drops...smooooth as
    On OC best ping was 180ms, now all game were 245ms or 275ms at worst
    and I still don't play it
  10. Renegade40D
    Renegade40D Member
    Aug 16, 2008
    1,382
    NSW
    Reinstalled to play on faceit but game gets massive fps drop and lag. Get high fps most of the time but as soon as anything happens it goes bad.
    What's the current trickery to get this game to actually run well?
    6600k @4.4, GTX 1080, 16GB ddr4, pubg installed on an m.2 drive.
  11. Bourke
    Bourke Member
    Jun 29, 2017
    465
    the biggest diff I saw in stats were the GPU @ 100% usage, it only has 2gb ram, my 1080ti usage was all over the place, the graph looked like a heart monitor.
    all that chop is gonna equal framerate drops.
    My NV settings were all standard, my PUBG setting were the same jus carried over copy/paste from other rig.
    Can you run AB with the same tags and see how it differs to mine.
    Also can you grab MAXMEM off techpowerup, jus run that and see what numbers it does.
    OS was brand new OEM WIN10 Pro updated
  12. Renegade40D
    Renegade40D Member
    Aug 16, 2008
    1,382
    NSW
    google said clear your steam download cache and verify game files, that seems to have helped.
    Also make sure nvidia control panel power mode is set to perfomance not efficiency
  13. xcessive303
    xcessive303 Member
    Apr 3, 2006
    167
    Had a few rounds of the snow map its actually pretty good. Feels alot better and the new parachute system is better. Still can't find any Oceanic games which is a shame although I only really play FPP...
  14. walker_2003
    walker_2003 Member
    Jan 15, 2003
    12,987
    had quick go to see if I could get a match, I like how it shows you if you will be redirected to SEA. Got instant squad TPP (not FPP :()
    New snow map, was cool.. Feels so odd after BFV.
    Seems like a lot of changes since I last played.
  15. Smegenstein
    Smegenstein Member
    Sep 12, 2008
    7,037
    Hobart - TAS
    I also jumped back on over my holidays to see whats up, I too like the match making changes (even though it seems if i want FPP i will end up on SEA). Felt weird as fuck to play, have they slowed down movement or has Warframe broken nearly every other 3rd person game for me now?
  16. walker_2003
    walker_2003 Member
    Jan 15, 2003
    12,987
    Warframe makes it feel like poop. Just like coming to PUBG from BFV. It feels so slow and clunky.
    My god I am bad at it now.. damn you BFV.
    BTW guys Exitlag works really well.. was getting 250ms to SEA now 110ms when I tried just now.. instant games..
    Free 3 day trial.
    https://www.exitlag.com/download
    Benno1988 give it a go if bored of BFV.
    New map fps blow.. stick to others. But it is a good map and tracking via footsteps is cool.
  17. walker_2003
    walker_2003 Member
    Jan 15, 2003
    12,987
    <3 exitlag.
    FPS seemed ok that time in snow map, maybe it is just parts that are unoptimised.
  18. ^catalyst
    ^catalyst Member
    11,958
    melbourne
    Yeah we've been using mudfish for the last few days, 90-120ms to SEA for FPP. It really makes it entirely playable.
    walker_2003 likes this.
  19. walker_2003
    walker_2003 Member
    Jan 15, 2003
    12,987
    Might give mudfish a go, seems cheaper then exitlag.
    Do I download their VPN or DNS?
    Edit: Even with 120ms ping I am still losing surprise confrontations.. both see each other around same time, I unloaded a good 5 shots, replay.. only 1 :(
    Maybe I just give up, he probly has ping of like 10ms.
  20. walker_2003
    walker_2003 Member
    Jan 15, 2003
    12,987
    ^catalyst care to share your mudfish settings? do you leave browser open? so far no luck, I think its made ping worse!
    In setup it shows im pinging SEA good but in game, nope 200-250
    edit: I think i fixed it by uninstalling kill ping which had control of the adapter.
    Do I need dashboard open to play? How much a month roughly does it cost? I probly play 10 hrs a week max.
    edit 2: Can close dashboard, and in cpl hours gameplay tonight only used 5 cents so its quite cheap.
    Even with decent ping I suck hard, BFV gunplay has ruined my PUBG recoil control. Also shot a guy 4 times tonight with K98 only to have kill stolen and then I got snuck up on :(
