Possible Group Buy - Check Interest - Lithium Titanate cells
Discussion in 'Hobby Engineering' started by rainwulf, Jul 15, 2018.
  1. OP
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    No, so im on a journey of discovery. On paper, they seem to be too good to be true. Their only downside is the energy density compared to Lipo, but when these things last at least 20 times longer, who cares.
    Building a monitoring system now, was going to drive to Jaycar to pick up some resistor ladders, but needed fuel in the car. Price is so high right now i think im going to stay at home and code.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    First module done.
    Run out of printer filament, so have to get more. These things will do 400-700amps short circuit without even blinking, so im making sure i can mount them solidly in any orientation and not have a huge short circuit.
    btw, this battery sits at 6.8kg, 40a/h, 12 volts. If you treat lead acid storage at a 25 percent depth of discharge, that means 40a/h is one quarter of an equivalent lead acid battery. That makes this here equivalent to a 160a/h AGM.
    160a/h agm does NOT weight 6.8kg. It also does NOT have a 20 thousand cycle life.
    To be conservative, i will treat this pack as a 120ah AGM. A 120ah agm weighs around 30kilos.
  3. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    5,957
    in your gearbox...grindin
    Can you start a diesel car with it :D ?
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    i wouldn't even hesitate. They are rated for 10-15c discharge.
    Leaving it on the alternator would be a disaster though. These things max at 13.6 volts. Charge them above that and i wouldn't want to see what would happen.
  5. mAJORD
    mAJORD Member
    Jun 4, 2002
    9,401
    Griffin , Brisbane
    Curious What did the individual cell weight come in at And why not 6 cell? Is the nominal and cutoff voltages closer to LA with 5?
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    around 1.2 kg a cell.
    LTOs run in groups of 5 due so they can be charged effectively. Their max full voltage is around 2.7 volts, so if they were in a group of 6, they would be sitting at 16.2 volts. They would never get a full charge.
  7. mAJORD
    mAJORD Member
    Jun 4, 2002
    9,401
    Griffin , Brisbane
    Is that problematic though if they don't get full charge, say for a car battery placement? All it would mean is an effective lowering of AH of the pack otherwise
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    Not really no, but then you would have to oversize the pack significantly to keep the AH decent, and you run the risk of flattening them to dangerous levels. It would work though, but yea you might lose 30-40 percent of your capacity.
    They are effectively "Flat" at 2.1 volts, which is still around 12.6 volts. That's above standard cut off voltage for all 12 volt devices, and they will continue to draw current past the "Flat" level possibly causing damage and shortening their life.
    edit: the specific cells im getting are 2.1 volts, apparently there are slightly different chemicals used by different manufacturers which can bring that down to around 1.8 volts which would fit well in a 6 cell pack.
  9. Privatteer
    Privatteer Member
    Mar 19, 2006
    776
    Any capacity test done yet?
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    Not yet, im still building the backs and mounting them safely. I do NOT want them to be knocked or fall over or have something conductive fall on them.
  11. Sunder
    Sunder Member
    Apr 26, 2012
    2,989
    Haha. I had them mounted/connected like you do. I needed to remove one cell to install a balancer... Didn't think it through too well, and undid a bolt, and the other bolt was not torqued up. As metal plates which are installed on bolts are wont to do, it pivoted on the remaining bolt, and hit the terminal below it causing a short.
    But even at 2.7v, the available current was so high, the force of the spark pushed the connector back up - then the force of gravity made it pivot back down, shorting it, and the force of the spark... You get the idea. Totally frightening, but no damage to the cells. (large chunks taken out of the connector though.)
    These things are bulletproof!
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    Yep, i did something similar, but with spacing my 3d printed mounts. I was spacing the copper link between two terminals to make sure my cradle wasn't too thick, and forgot the other ends of the cells where already joined.
    DAMN. My cells aren't even fully charged, sitting at about 2.1 volts atm, even so the current they put out is fucking ridiculous. Btw, check the data sheet, you can charge each one at 400 amps. safely. 4 bloody hundred amps.
    Btw, what balancers are you using? I have a bunch coming from ebay now.
  13. Sunder
    Sunder Member
    Apr 26, 2012
    2,989
    Not so much balancer, as a HVC safety:
    https://www.ebay.com/itm/Hot-Sale-2...964?_trksid=p2349526.m4383.l4275.c10#viTabs_0
    These are super cap balancers. Supposedly burn off 1A once it reaches 2.8V in reality, at 2.85v it only burns off about 200ma. At 3.2v (Simulated without a battery), it I get it to 700ma, but didn't want to go over that, because if the battery is over 3.2v, I'm up shit creek anyway.
    It's "good enough" for a holiday home off grid solar array, because I only trickle in for like 1-10A (Theoretical 540w system, 24v bank - in reality I get nothing near that) a few hours a day and a solar charger "should" provide a secondary high voltage cut off, and it has plenty of time for the rest of the day to balance, so unless one completely fails, then it'll never get that far out of whack. I'm not sure I could recommend them with a big system though.
    For my motorbike, which I'll be charging at either 2400W or 4800W (depending on home charger or public electric car charger), I'm thinking of using a proper one like this:
    https://www.aliexpress.com/item/35S...4cb5-47af-bff8-48007d7fac95&priceBeautifyAB=0
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    hahaha, thats exactly what im going to be using for the solar storage array, as its charge/discharge voltages i can control exactly.
    And yea, its more of a last ditch protect each cell on its own kinda thing.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    Well, got the bank running today on Solar. Was sucking down 60 amps at 24 volts nicely until i started to measure individual cells. Definitely need balancing before anymore charging is done, probably a long slow balance charge before putting them into production.
  16. rockofclay
    rockofclay Member
    Nov 10, 2002
    1,441
    Melbourne, 3056
    Damn, these look good. I'll definitley have to pick some up if a group buy goes ahead.
  17. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    5,957
    I was kinda thinking of a portable 12v battery, jump starting when you've got a dead battery rather than an outright replacement.
    so the different cells are sucking down juice at different rates, hmm that could be problematic.
  18. aXis
    aXis Member
    5,164
    Kalgoorlie, WA
    I've got a small solar setup and the lead acid batteries died on the weekend. More motivation to look at alternative batteries again, just a shame about the shipping costs!
  19. aXis
    aXis Member
    5,164
    Kalgoorlie, WA
    Was doing more hunting on Aliexpress and came up with similar (or the same) batteries at $80 a piece landed in small quantities. They rate them as 3000 cycles up front and then later specs have 25000 cycles. 3000 is still nothing to be sniffed at though. At that price point they are only slightly more expensive than the cheap end of LiFEPO4, with triple the life.
    https://www.aliexpress.com/item/2pc...CS-3000-Cycle-times-10C-2-4V/32921202689.html
    Also very interesting was this 80 amp LTO BMS, for a very reasonable price. The 10S version is $86 landed.
    https://www.aliexpress.com/item/Bat...5S-80A-2-4V-With-Balance-For/32927200199.html
  20. mtma
    mtma Member
    Aug 12, 2009
    4,696
    Their 100 piece lot is about AU $ 0.60/ Wh before tax., about $55 each plus local duty or inspection fee if the aliexp shipping fee is correct. Although I note on the CALB stuff in the store they have a note about needing to contact them for a shipping fee.
