Power Saving device... Remote control 240v
Discussion in 'Electronics & Electrics' started by BilboBoggles, Jan 16, 2008.
  1. BilboBoggles
    BilboBoggles Member
    Jul 20, 2006
    112
    Hi all,
    After buying a Jaycar power meter I was amazed to see just how much standby power some of my equipment uses. Obviously the best option is to unplug or switch off at the power point. Problem is that it's a pain in the neck to reach the power points in my study.
    Browsing through Bunnings the other day I found this
    For around $39 (IIRC) you get one remote controller and three plug packs.
    I've now grouped each PC onto it's own power board including all accesories and plugged it into one of the plug packs. The controller is mounted using Velcro next to the light switch. It's very easy now to completely power off each PC and all of it's accessories.
    I beleive the plug packs use some power - but it's less than 1 watt - or right at the lowest level my power meater can measure.
  2. BenJ
    BenJ Member
    Feb 9, 2003
    311
    Sydney, Australia
    Hey, that is pretty neat.
    I will keep an eye out for them.
    BenJ
  3. junglist
    junglist Member
    852
    Launceston, Tasmania
    is that IR? i've been looking for something like that so i can control lights etc with my harmony remote
    BilboBoggles
    BilboBoggles Member
    Jul 20, 2006
    112
    No - It's UHF based - so works through walls etc.
  5. Widowed
    Widowed Member
    Nov 26, 2005
    640
    We have four of these aswell.
    2x for computers + Accessories
    1x TV, Stero, DVD/VCR (Entertaining RM)
    1x TV, DVD (my room)
    :thumbup:
  6. ir0nhide
    ir0nhide Member
    Oct 24, 2003
    4,471
    That's pretty damn awesome :thumbup:
  7. broox
    broox Member
    Apr 27, 2006
    3,600
    Ad'laide SA
    very cool! i mite have to find me some of thems!
  8. Meddish
    Meddish Member
    Dec 5, 2006
    803
    Newcastle
    there is also the same thing that runs the main's switch on a cable to a sorta lightswitch sorta thingy ive got one of these mounted in the bedroom so it kills PC+TV in one click! (and means i dont have to bend down to get to the stupid switch when there is a storm!!)
    also cuz its a switch it uses 0W when off!
  9. Imitation
    Imitation Member
    2,861
    That's pretty good.. handy. Good for the elderly or those hard to reach places for example.
    My parents looked at a display home not long ago and the builder put switches at waist height near where the TV would go for example.. so you can easily turn the power off at the switch for maybe two or three power points and turn off all of your AV equipment at once without bending over.
  10. dbgeek
    dbgeek Member
    Feb 17, 2008
    2
    I used to have one of those it worked well.
    Now I have a relay setup with hidden microswitches.
  11. Symon
    Symon Castigat ridendo mores
    Apr 17, 2002
    4,722
    Brisbane QLD
    I wonder how much standby power those devices use? :tongue:
  12. Jay
    Jay Member
    Jan 7, 2002
    2,389
    I think that's what he meant.
  13. LethalCorpse
    LethalCorpse Member
    Mar 23, 2003
    3,760
    Cambridge, Massachusetts
    I was thinking the same thing till I read that. Seems they're not so bad. I know the UHF receiver modules do run on bugger all power, though there's probably a bit more draw when it's driving the SCR.
    EDIT: beaten...again...
  14. Badooleoo
    Badooleoo Member
    Oct 25, 2007
    316
    Interference
    Excellent idea I might get a few of these myself.
    I wonder how many of these you can have before you start running into interference problems.
    Also if you know someone with these how easy would it be to spoof it.
    Also whats the range of these?
  15. LethalCorpse
    LethalCorpse Member
    Mar 23, 2003
    3,760
    From the looks of this system, one kit is all you could use within the range of the remote. You could add extra receiver sockets, but they'd still be switched in three groups - ie channel 1 on one remote will switch all the channel 1s. Jaycar have some that you can have up to 255 selectable frequencies, but they're OEM relays, so you'd have to put them in a box with plug and socket, or mount them inside the controlled equipment.
  16. Badooleoo
    Badooleoo Member
    Oct 25, 2007
    316
    Info on the Arlec RC3
    Went to the Arlec website and searched for RC3 and found it, also has the manual in PDF http://www.arlec.com.au/instruct/RC3.pdf
    It uses 433.92 MHz which is in the 70cm (UHF) amateur band and uses "advanced self-learning operation code ability" as the manual says. Still not sure on the interference but I might buy a couple if I can find some.
  17. Oosh
    Oosh Member
    Oct 31, 2002
    9,280
    What's the limit on the load they can handle?
    And hopefully they're better put together than the Arlec timer I had, it just past 12 month warranty, and plastics inside cracked and fouled the timing gears.
  18. MUTMAN
    MUTMAN Member
    7,780
    4109
    second photo kinda tells you, but you've got to look really close
  19. Suntzu
    Suntzu Member
    1,823
    I got a cent-a-meter installed the other day after buying off ebay for $155 and its friggin awesome. Tells me my entire household power consumption in real time.
    On of these new gadgets about is just what i need to top it off. You wouldnt believe the power my AV gear draws on standby!
  20. Oosh
    Oosh Member
    Oct 31, 2002
    9,280
    Damn you for not entertaining my lazy ways. I had the read the PDF! :D
    10A, 2400W, standard stuff, no worries.
