Precision 3D Printer Build - Worklog
Discussion in 'Hobby Engineering' started by aokman, May 28, 2019.
  1. djdude1010
    djdude1010 Member
    Mar 26, 2003
    701
    Wow this thing looks great. Can't wait to see it completed.
    80/20 is such a nice material to work with.
    Would love to try and make a CNC one day. Similar sort of build work.
  2. Cererus
    Cererus Member
    Jan 14, 2002
    1,506
    Looks good but as an ex tool maker I shudder at the pics of micrometer/g clamp.
    This thing is looking like a mill not a printer, why the vices?
    aokman
    aokman Member
    Jul 12, 2001
    12,670
    Not using it as a clamp :lol: was measuring the ways to see if the height is consistent end to end with a gauge block under it. The vices are for milling the extrusion / will be face milling the bed, they can open to 200mm and can also be split to create one large vice across the bed.
    aokman
    aokman Member
    Jul 12, 2001
    12,670
    After months of preparation... it finally arrives!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  5. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,128
    Perth , East Vic Park
    That must have set you back a few dollars. BF20 is like $2k+ so I fear the BF50 cost.
    aokman
    aokman Member
    Jul 12, 2001
    12,670
    A lot, it may look similar to a BF20 but shares nothing really other than the look, factory fitted DRO, pneumatic draw bar, Z and X axis power feeds, ISO40 taper and 2.5kW gear driven spindle. 600KG with the base :upset:
  7. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,128
    Yeah mills go up in price really fast. I have a pretty small one (Bit smaller than a BF20).
    I went and checked and they are like 10K, I hope you like metal working.
    aokman
    aokman Member
    Jul 12, 2001
    12,670
    Love it! It has been a dream machine of mine for a long time and this project was ideal for it
    aokman
    aokman Member
    Jul 12, 2001
    12,670
    An action packed week so far! Was a VERY difficult lift with this mill, so many hurdles that had to be overcome but it is now in its new home :) also attached an example of the work it will be doing with the vices.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    SimParadox likes this.
  10. m3k
    m3k Member
    Dec 29, 2007
    660
    kinda - some filaments care more than others removing as much lash as possible can get you to print very small islands and tiny features without oozing and quicker shorter retracts causing much sharper start and end loops and much sharper looking prints just the nature of the beast u can compensate but sometimes whats best is a direct drive-
    but like if you're rapid prototyping who cares- but if you're trying to make some FDM artwork that needs little to no sanding and priming etc then you get a bit try-hard about backlash not so much in the extruder but the whole stystem because shifted layerlines look like butthole and make everyone think 3d printing sucks but when the layers are perfectly ontop of eachother people respect the quality alot more and it also makes finishing less difficult
    ive found preloading axis the best to increase repeatability and make the layers look the most consistent- ironically very canter-leaved printers (which ive found people have such a problem with) - with direct drive tend to have wicked good surface finish when printing slow- because everything is "resting" in the same position every layer at a time.. its great
    a older printer that comes to mind is the up plus 2 or the new cetus etc
    back on topic i love the mill... thank you so much for sharing
    aokman likes this.
