[WIN7] Prevent users from accessing my drive
Discussion in 'Windows Operating Systems' started by WhiteFox, Feb 11, 2018.
  1. WhiteFox
    WhiteFox Member
    Oct 12, 2003
    82
    Singapore
    I have 2 HDD in my PC, C and D drive. C drive is where windows is installed and D are where everything else is. My dropbox and onedrive are pointed to folder in D drive, D:\Dropbox and D:\OneDrive.
    I have 2 users on my PC, myself (admin acc) and my sister (normal acc)
    How do I prevent other acc other than mine from viewing or accessing my folders in D?
  2. self_slaughter
    self_slaughter Member
    Dec 12, 2010
    1,097
    4165
    It's been a long time since I've used windows, but I think something like this would work.
    Right click drive folders you want to deny access to, go to properties, open the security tab, press edit, then remove the users you don't want to have access to the drive.
    Edit: Not sure if removing users completely or setting the deny flag on non admin users is the better option. But I think either should work for your scenario.
    Just poke around and see what works best for you. :)
    WhiteFox
    WhiteFox Member
    Oct 12, 2003
    82
    Singapore
    I'm afraid it might lock me out as well cause I'm also under an authenticated users?
    If kind of does in synology settings
    WhiteFox
    WhiteFox Member
    Oct 12, 2003
    82
    Singapore
    ok, solved. I added the user account in the properties and then checked under deny
  5. self_slaughter
    Dec 12, 2010
    1,097
    4165
    ahh groovy. I haven't touched windows in so long, forget what overrides what.
    Glad ya got it sorted. :)
