Problem with links in InDesign
Discussion in 'Graphic Design & Digital Art' started by spotted, Jan 25, 2019.
  1. spotted
    spotted Member
    Nov 10, 2010
    325
    I'm trying to edit a file in InDesign. Following tutorials I added a hyperlink to some text but I found that there are no character Styles that I could select to make it look like a hyperlink. Also I could not create a new style. What am I missing? To link works when I export PDF but the text doesn't look any different.
  2. argent
    argent Member
    Mar 20, 2003
    2,168
    fullarton.adl.sa.au:5063
    What do you mean by you cannot create a new style?
    spotted
    spotted Member
    Nov 10, 2010
    325
    Tutorials say select a style to make it blue underlined. There's nothing in the dropdown. How do I create a new style?
  4. argent
    argent Member
    Mar 20, 2003
    2,168
    Goto Window > Styles > Character Styles (or hit Shift + F5 if you haven't changed your shortcuts)
    Select New Character Style from the burger menu in the top RHS of the Character Styles window/drawer
    Define your Character Style ie. name, underline, character colour etc.
    Highlight the text you want to change and then double click on the newly created style in the Character Style window
    spotted
    spotted Member
    Nov 10, 2010
    325
    Thanks that's what I needed!
  6. telefragd
    telefragd Member
    Dec 21, 2003
    355
    Perth, WA
    FWIW there’s an automatic style (you still need to make it a proper style though) that gets applied to text links if you’re using the Interactive panel. Any text links you create get automatically set to blue and underlined.
    Using styles properly is what you’d want to do regardless.
    spotted
    spotted Member
    Nov 10, 2010
    325
    It's the automatic style I couldn't find. It's a bit awkward now I have to make this style in every new doc ( or copy it)
  8. argent
    argent Member
    Mar 20, 2003
    2,168
    Just import from the file you got it all setup.
  9. telefragd
    telefragd Member
    Dec 21, 2003
    355
    Perth, WA
    No need to even do that.
    If you open up InDesign without opening a document, you can alter the default styles and even colour swatches. Every new document you create from then on will then have all of these set already.
  10. argent
    argent Member
    Mar 20, 2003
    2,168
    Only worth doing if you are 'in the business' so to speak - if you are simply a piecemeal/once in a blue moon type user, it would probably be simpler to just import.
