Problems with M.2 NVME drive
Discussion in 'Storage & Backup' started by Will S, Jul 31, 2016.
  1. Will S
    Will S Member
    Aug 15, 2003
    5,639
    Coniston (Wollongong)
    Samsung 512GB SSD, 950 PRO Series, m.2 (PCIE)
    Getting error messages when starting PC ( only installed win10 on new system yesterday ) ...errors detected on C drive and win10 scanned and fixed them..............
    Now no idea with these new drives..........I had a google and found a Samsung driver for Samsung 950.........but not sure about updating the driver on the o/s drive whilst running the o/s..............
  2. Borat
    Borat Member
    Mar 13, 2005
    91
    QLD
    Couldn't hurt to install the driver - this should at least help with monitoring your temps, especially if it's installed on an ITX board & on the back... :leet:
    Do you keep getting the errors/fix with each boot?
  3. ics
    ics Member
    Jul 8, 2002
    209
  4. McRutch
    McRutch Member
    Jul 10, 2011
    231
    i've run the 950 on windows 7, 8 & 10 with & without the drivers on all 3, and never encountered that problem.
    sounds like a corrupt windows install, or a faulty/overheating drive to me :confused:
  5. Renza
    Renza Member
    Dec 1, 2004
    4,873
    You will get a huge performance increase if you do install the drivers, however.
  6. aussie-revhead
    aussie-revhead Member
    Feb 21, 2005
    19,845
    St Clair 2759
    Mine was the same before and after driver install.
    :thumbup:
    Will S
    Will S Member
    Aug 15, 2003
    5,639
    I am tending to think the problem is with the motherboard. Getting a few upgrades for the BIOS in a short period which makes me think there may be probs with it. Actually PC is working ok and boots ok but not with a cold boot ( after main power is turned off lor blackouts ) and then I need to hit the power boot key on the case .
