Project: Aerodyne
Discussion in 'Modding Worklogs' started by slipperyskip, Nov 28, 2011.
  1. OP
    slipperyskip
    slipperyskip Member
    Jan 27, 2004
    520
    Florida
    In this video I show-off an absurdly over-engineered front USB port cradle made from scrap wood and demonstrate how it fits into the box.
    Located and cut a small square hole in the top of the USB support cradle.
    The cradle will be pinched in place by the cover plate when it is eventually glued in place. The cradle is to remain "free" in case the ports need to be replaced.
    The holes align with the grilles' location peg. When inserted the peg keys the USB cradle in place.
    Spent about two hours with some hobby files rounding over the edges of the grilles' supports/separators. Minor detail but it is a dramatic improvement in the appearance. Might not be so dramatic in a photo.
    Still picking that scab. These are templates for cutting the aluminum for the DE. The idea is the inlayed aluminum would be raised above the mahogany surrounding surface instead of flush fit. Also toying with the idea of coloring the lower hemisphere in something bright like red. Maybe brass?
    Still looking at other alternative designs while I'm waiting for the delivery of my stainless steel power push-button.
    Thanks for looking.
  2. [RMS] ST1NG3R
    [RMS] ST1NG3R Member
    Feb 8, 2010
    446
    3170
    slipperyskip = the king of wooden PCs. awesome build mate, cant wait to see with the veneer on!
    slipperyskip
    slipperyskip Member
    Jan 27, 2004
    520
    Florida
    Thanks! :thumbup:
    The I/O shield spans over a large portion of the case's width. Adjustments must be made. The idea of doing this step was a big breakthrough while designing this case in my head. I was stuck on trying to fit the mini-ITX board into one compartment or the other. Using the entire volume of the case interior meant eventually having to cut a notch. Note: The motherboard is mounted upside down (relative to this photo).
    Most of the material is carved out using my razor knife.
    Stainless steel power button that was originally intended to be a starter/horn button for a custom motorcycle.
    Goodies from Crucial arrived. Continuing the theme of complete overkill, 8GB of DDR3 and a 256GB M4 SSD.
    Brackets made from aluminum angle.
    Wooden brackets for the aluminum brackets.
    Something like this. I'm going to wait for the wiring phase to determine the exact location of the SSD.
    This post brought to you by....
    slipperyskip
    slipperyskip Member
    Jan 27, 2004
    520
    Florida
  5. Moptimus
    Moptimus Member
    Aug 22, 2011
    1,095
    Nambour-by-the-Sea
    Are there any issues with grounding the PC when you use a wooden case or do you account for that with the wiring?
    slipperyskip
    slipperyskip Member
    Jan 27, 2004
    520
    Florida
    The issue of properly grounding electrical devices was resolved many many years ago with the adoption of grounded three-prong electrical outlets. I'll assume OZ uses three prong outlets. The third prong is a common ground wire. Every component in your computer has at least one black ground wire that can be traced back through the power supply and into this third prong. Anyone telling you that the problem with your component is that it isn't properly grounded to the case is FOS.
    slipperyskip
    slipperyskip Member
    Jan 27, 2004
    520
    Florida
  8. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    Melbourne, VIC, 3127
    Cute puppy :D
    Well done on the case too, can't wait to see it full of smexy hardware :thumbup:
  9. K O J A K
    K O J A K Member
    Jan 14, 2010
    103
    Perth, W.A
    Very nice. Can't wait to see the final product.
  10. CREDO
    CREDO Member
    Feb 2, 2004
    750
    Perth, 6027
    Oh that made me laugh. :D
    Awesome work.
  11. BlueRaven
    BlueRaven Member
    Jul 29, 2010
    4,330
    Stuck in Sydney traffic
    More, for the love of god, more! :leet:
  12. Pipster
    Pipster Member
    Sep 23, 2008
    584
    love the art deco theme in so much of your work.
    Subbed :)
    slipperyskip
    slipperyskip Member
    Jan 27, 2004
    520
    Florida
    Her name is Jade. The smexy hardware is...ah...coming.
    Thanks. I estimate the project at about 80% right now.
    Thanks. :thumbup:
    OK. Here's some.
    I like Art Deco and it doesn't hurt that it easy to do. I'd be in trouble if I liked Rococo. :)
  14. leithals
    leithals Member
    Feb 23, 2011
    694
    Central Coast 2257
    Not much more you can say but wow... :thumbup:
    the level of workmanship is amazing. Carpenter by trade? Love it.
  15. admiralranga
    admiralranga Member
    Aug 8, 2011
    299
    Claremont, WA
    veneer is looking awesome
    +1 to this
  16. kombiman
    kombiman Dis-Member
    Dec 3, 2006
    12,741
    viva brisvegas
    I'm glad it passed the Lab test ;)
    Labrador test... geddit... giggle
  17. brayway
    brayway Member
    Nov 29, 2008
    6,831
    New Zealand
    Looks fantastic so far!
    but then again you always do a good job :)
    slipperyskip
    slipperyskip Member
    Jan 27, 2004
    520
    Florida
    Thanks. Four professions, none of them carpenter.
    Tested positive for working with cheese doodle fingers. :)
    Thanks brayway. Glad to see you're still around.
    Draw, score, drill, rasp, sand, sand some more, frame, veneer, sand = 14 hours.
    slipperyskip
    slipperyskip Member
    Jan 27, 2004
    520
    Florida
    Couldn't go thru the project without at least one clamp sculpture.
    Before and after one application of teal oil.
    Framed up the mesh and painted the interior except for glue-down surfaces and "working" surfaces.
    Thanks for looking.
  20. Craggles
    Craggles Member
    Aug 31, 2006
    872
    This looks fantastic.
    Excuse my ignorance but how do you power these small motherboards?
    I'm yet to see a psu?
