Project "ARES 509" anniversary build
Discussion in 'PC Build Logs' started by Seanay00, Oct 20, 2016.
  1. Seanay00
    Seanay00 Member
    Dec 2, 2012
    234
    Hey guys,
    Well i think its time for a build log of my current ROG build. After my trip to taiwan and computex i really wanted to something great and unique for a ROG build. I wanted every part to be ROG branded and i wanted it to incorporate the 10th anniversary of ROG.
    So with that being said ive decided to roll with hardware that i personally feel demonstrates the engineering perfection that ROG produce. This build will not be the final product there will be changes and upgrades as i go and acquire more ROG hardware. WIth all that said this is my hardware list for the ARES 509 build.
    CPU - i7-6700k
    MB - Maximus VIII Formula
    RAM - Avexir Tesla ROG 4x4gb 2666
    GPU - ARES III
    SSD - Intel 600P 256GB m.2 / more to be confirmed
    HDD - WD Black 1TB x2
    Cooling will consist of a full EK loop with 1 maybe 2 360mm rad's depending if stage 2 of this build takes off. If it does i'll be a very happy man
    I will keep you updated as much as i can, home and work life are going to be very busy from now until christmas but i will update as soon as i can. Follow my facebook page KWASTEK and my instagram @Kwastek_ for updates also.
    Now a bit of a look at the hardware....
  2. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    1,980
    Nulkaba
    Looking forward to seeing what you come up with:thumbup: , but I cant see any pics:(
    Seanay00
    Seanay00 Member
    Dec 2, 2012
    234
    Yea i linked them from my ROG forum post but you need to be logged in to view them, just realised. I need to change it.
    Seanay00
    Seanay00 Member
    Dec 2, 2012
    234
    pictures fixed!
  5. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    1,980
    Nulkaba
    yep I can see thems:)
  6. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    1,980
    Nulkaba
    any progress;)
    Seanay00
    Seanay00 Member
    Dec 2, 2012
    234
    Just about to kick it all off soon mic. Been flat out with work!
    Seanay00
    Seanay00 Member
    Dec 2, 2012
    234
    Ok so the build has changed a few times since i've gotten ahold of a bit more hardware! So now the build is going to contain the following.....
    Crosshair VI Hero
    Ryzen R7 1700
    2x Ares 3 gpu's (yes i found a second one)
    The rest of the build should remain the same. I will update with some pix on the weekend once i get some spare time :thumbup:
