[Project] Blue Nova
Discussion in 'Modding Worklogs' started by Aborted, Nov 22, 2008.
  1. Aborted
    Aborted Member
    Nov 22, 2008
    49
    Hey guys, Im an Australian modder from Melbourne, so Ill contribute to this forum!
    The aim is to successfully modify a Lian Li A07B case, with quality in mind. The case will have a blue futuristic feel to it. I will be spray painting and mounting a AC Ryan Rad Grill on the front of the case with hex key screws and spacers. I will be creating a stencil and spraying it on the front and top of the case. The front and back stock fans will be removed and Coolermaster 120mm fans will replace. 2x120mm fans will be installed on the top of the case. The case will also be powder coated a gloss white or matte. A lot of extra mods will be added in the future.
    *Thanks to GAMMODS for supplying me with the materials!*
    Materials:
    - Lian Li PC A07B
    - Clear Side Panel
    - 2x120mm Coolermaster Blue LED Fans
    - 2x80mm Blue LED Fans
    - Spray Paint
    - AC Ryan Radgrill
    Modifications:
    - Cut out Radgrill template on front panel for mounting
    - Mount Fans
    - Make Stencil
    More to come…
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    Reserved.....
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    Painting The Grill
    Painting The Grill
    Sanded Down with 280 Grit
    Ready to prime
    Primed 1st Coat
    Sanded Again
    I sanded and primed like a million times.
    I then added the Cyan Blue Colour. This is what I came out with. Money Shots.
    Tell us what you think. I'll be adding ALOT more later. I just got quoted $75 for powder coating, for TWO CASES! I think its pretty cheap. Thanks. :thumbup:
  4. jamesl33t
    jamesl33t Member
    Oct 7, 2007
    636
    sydney
    Nice work with the grill - really clean.
    Also, that's really cheap...I might look into powdercoating mine. :tongue:
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    Cutting RadGrill Template
    Used a Jigsaw. Pretty old LOL.
    Just cut out the basic outline, didnt make it too accurate. As I was going to fix it up with a file.
    I sort of came up with my own solution to making things perfectly straight with just a file, clamp and a peice of aluminium! Here we go! Just clamped the aluminium in the spot I wanted, made sure it was straight and filed!
    Took about 10 mins and I have finished JUST the bottom edge!
    All Done!
    Perfect.
    Dunno why I tried to make it so perfect when I am using U-Channel from GAMMods on it lol. Thanks.
    :thumbup:
  6. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,449
    Nice start keep up the good work.
  7. B4TM4N
    B4TM4N Member
    Jan 30, 2008
    427
    3128; Vic
    Hey mate
    Looks nice, keep up the good work! :thumbup:
    Who where those powder coaters that gave you the cheap quotes
    I'm in Melbourne looking for cheap powder coaters :)
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    The powder coating company is called Excite Powder Coating. They have a website. Thanks guys!
  9. JuzIE
    JuzIE Member
    Nov 22, 2008
    849
    Sutherland Shire, Sydney
    Looking good, keep it up :)
  10. TMM
    TMM Member
    Mar 29, 2005
    7,481
    nice attention to detail :thumbup:
  11. archibaw
    archibaw Member
    Sep 8, 2008
    271
    Tamworth NSW
    Looks great. Keep up the good work. :thumbup: Look forward to following this one.
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    I think I did OK for my first time using a jigsaw to cut aluminium. I also painted a mesh grill the same Cyan Blue colour as the front Rad Grill. Check it out :thumb:
    All marked up!
    Used that back fan hole as a template.
    Time to cut.
    So far so good!
    All done! Im pretty happy with the cut.
    Priming the mesh grill. Primed it 3 times.
    Damn! I made a bad gash with the clamp a while back. Just noticed it then. Will this matter when I get it powder coated? How do I fix it?
    Grill mounted up!
    :thumb:
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    Switch's
    Sorry guys for taking so long on an update, my dad has been busy with work, and I haven't been able to get any transport ANYWERE! Well I've been 'Promised'! that we will go on monday to get my:
    * Socket Hex Cap Screws - For mounting Rad Grill and fans.
    * Cable sleeving
    * POWDER COATING! - I seriousely cannot wait! I've literally had dreams of getting it done.
    Anyways on with the extremely small update! I bought a 16mm and 22mm Holesaw to cut holes in the front panel to accomodate my new bulgin switches, that will shine White when on!
    Ready To Cut the 22mm Hole
    My 16mm Hole saw the cost me 30bucks!
    Ok so long story short. (I forgot to take photos) here are the switches temporarily mounted.
    Ok so a very disappointing update, but it’s better than nothing! Peace out!
    :thumb:
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    Powder Coating
    Hey guys! After 2 Weeks and 1 day!!!!! I finally get a phone call saying that my computer case is READY! Omg I was so happy. I guess that is what you get for $75 lol. Anyways here you go. Check the pictures out and tell me what you think! :thumb:
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    Assembly (1)
    Hey guys, been a bit busy with training, and learning. But I've almost fully assembled the case, just gotta do a bit more soldering on my bulgin switches, and order some more thumbscrews as I lost my spares lol. Anyways here you go.
  16. BigDave
    BigDave Member
    Nov 12, 2007
    3,700
    ADELAIDE/5018
    Hey Aborted, That looks great,:thumbup: does it look as good in in the flesh :cool:
    I only have 1 pet HATE, those ugly allen head screws, round headed ones will look 100% better IMO. And once again It looks GREAT.:thumbup::cool::thumbup:
  17. slamaa
    slamaa Member
    Jun 1, 2006
    2,064
    Reservoir, VIC
    Very nice, though I think it would look better is you mounted the grill flush to the front panel and turned it 90 degrees.
    Other than that very pro work :thumbup:
  18. C0L0N3L
    C0L0N3L Member
    Apr 18, 2006
    701
    That's a very clean mod Aborted.
    $75 for powder coating.. seems an alright price
    I think i have to agree with Slamaa about the grill on the front unless it's for has some purpose.
  19. GTZLevin
    GTZLevin Member
    Jul 12, 2005
    544
    Gold Coast
    loving the white powder coat.. very pimp. Almost hurts the eyes.
    How are u going to go with cabling the beast to keep it look pristine?
    Aborted
    Aborted Member
    Nov 22, 2008
    49
    Hey boys thanks ALOT for your feedback, Its great to hear from some fellow Australians, as I mainly go on the Overclock.net forums. Appreciate it.
    Haha hey Dave, Well I have a fetish for those allen head screws, dude sorry but I cant help it. Ill buy some rounded ones and see what they look like and post some pics. Thanks for the feedback!
    Thanks m8. Yeah Ill definately get some smaller spacers, I like the extruded look, Ill just have to make it not so extruded lol. I think rotating it 90 degrees will fit, Ill give it a go. Thanks!
    Yeah, Excite Powder Coating is the name of the powder coaters. Mind you it took them 2 weeks.
    Yeah hurts my eyes aswell haha. Im actually selling this case as I am broke and need a sig rig, Its a shame I know, but I have to. I train 10 times per week as a swimmer, and I hold the state title in the 100 and 200 breastroke, so Im fairly busy lol and cant get a job haha!
