Project: BlueSparkle
Discussion in 'Modding Worklogs' started by [D]ark[A]cid, Aug 15, 2006.
  1. [D]ark[A]cid
    [D]ark[A]cid Member
    Nov 2, 2005
    144
    This computer is for my sister, for her bday present. I'm not doing a big write up of everything as its all fairly common mods, pics will tell most of the story.
    Bought this case off the OCAU forums.
    The previous owner started removing the fan grills and did a real hack job :S and he's also used paper to cover any vents or fanholes not being used with fans for some reason.
    The case panels have an interesting design. The top panel is secured with one screw, you remove that and then slide the panel off.
    The side panels are held in place using the normal side panel slide mechanism things, except in this case it is made to slide vertically, so the top hold the panels on the case.
    Onto the Modding....
    I marked out the front fan holes to be removed.
    Unfortunately I forgot to get a pic of it cut out. But here is a pic where it has been cut out, and I have marked out the next cut, to make room for the front 92mm blowhole fans to fit.
    Now for the front panel I planned for 3 x 92mm blowholes.
    First hole was cut using a variable holesaw.
    This was a bit too aggressive for the plastic so I decided to dremel the other two holes out.
    90mm pipe is cut to rough size using a dremel, and positioned in the front panel.
    Some all pupose glue is used to hold it in place for the time being.
    Then as things are all going smoothly, I start to cut the pipe flush with the bezel, then all of a sudden my dremel clone dies on me. I open it up and with a bit of fiddling i seem to have fixed it, but it wouldnt fit back together :S So being in a rush, my dad bought me a dremel multipro.
    Using my new dremel, I finished off the cuts to make the pipe flush with the bezel.
    Bondo is used at the back to secure the pipes strongly.
    cannot fit all images in this post. will continue next post.
    [D]ark[A]cid
    [D]ark[A]cid Member
    Nov 2, 2005
    144
    First layer of bondo after a little sanding.
    Second layer (I think my bondo skills are improving)
    The Back Panel has restrictive fan grills, and an ugly little grill and these old port space things on it, all to be removed.
    Marked for cutting, and the mesh I plan on filling the holes with. MAD, your mesh has proved to be extremely helpful, ty mate!
    Forgot to take a picture of the completed cut, DOH!
    Anyway, here is the case unassembled, ready to be painted, you can see the finished cuts in here.
    I need something to mount that front blowhole fans to, so I got a sheet of plexi marked it out and started cutting,
    The side panel was taped off, and marked for cutting of the window.
    Halfway through cutting I scrapped the design and just made it into a square rounded window.
    There will be more updates coming real soon..
    All comments are really appreciated and I love feedback..good or bad.
    I would like to thank Iridium Technologies for hosting my photos!
    http://www.iridiumtechnologies.com.au/
  3. -KoMoD0-
    -KoMoD0- Member
    Dec 26, 2005
    9,033
    Western Sydney
    Looking good
  4. slamaa
    slamaa Member
    Jun 1, 2006
    2,048
    Reservoir, VIC
    Nice work so far. looks like the start of a real nice case :thumbup:
  5. MrSmith
    MrSmith Member
    Jul 7, 2005
    2,376
    nor perth
    Looks great so far :thumbup:
  6. ener
    ener Member
    Dec 23, 2005
    3,620
    Gold Coast
    ^^^ as above :thumbup: ^^^
    cant wait to see the front finish i reckon that will be the stunner
  7. n00by
    n00by Member
    Jul 13, 2005
    2,152
    Sydney, 2219
    nice so far... keep the updates regular :leet:
    [D]ark[A]cid
    [D]ark[A]cid Member
    Nov 2, 2005
    144
    Second layer sanded, getting a nice shape.
    3rd layer on.
    3rd Layer sanded.
    A black guide coat was sprayed on and then sanded to show up the lower areas better.
    All the lower black areas have bondo smoothed over them.
    Sanded back smooth.
    The top was bondoed at the last minute when I realised the removable part of the bezel was not level with the actual bezel frame. Shitty photo sorry guys.
    [D]ark[A]cid
    [D]ark[A]cid Member
    Nov 2, 2005
    144
    Picked up some things at bunnings to use for the fans. In the shop they seemed perfect, and I was going to cut down the one on the left at the base of the actual cone part.
    But once I put them on the fans, they seem way too small. There was nothing bigger at bunnings and being too young to drive, I can't really go around to different shops looking for the right thing so these might have to do :(
    Prepping for Paint.
    I bought some new rolls of sandpaper and sanded back the panels.
    Completely sanded with 80grit.
    And since quite a few people from different forums have asked me what colour it is going to be. I'm using this Metallic Blue on the outer panels and bezel, and flat black on the inside.
    I've already finished painting the inside flat black, and I will most likely have another update later tonight of the case internals being assembled.
  10. n00by
    n00by Member
    Jul 13, 2005
    2,152
    Sydney, 2219
    looking good
    keep it up!
    at least something is happeneing in here to keep us occupied...
    Defyant hasn't made a post in ages
  11. Mensuri
    Mensuri Member
    Apr 21, 2004
    746
    looking good, what brand fans are you using?
  12. bayan
    bayan Member
    Jan 26, 2006
    208
    Geelong, VIC
    Keep Up the good work m8 :thumbup:
    Looking forward to final touch/look
  13. .LiQU!D.
    .LiQU!D. (Banned or Deleted)
    Oct 29, 2005
    3,449
    Pro-shit dude, I'm assuming you're under 17, in which case fucking good work! :thumbup:
    Love the paint colour, Sapphire/Cyan metallic is awesome.
  14. MrSmith
    MrSmith Member
    Jul 7, 2005
    2,376
    nor perth
    I thought he was like, 19.
    Good work again, those knob things are interesting..
  15. silenthunter
    silenthunter Member
    Aug 29, 2002
    2,634
    Amsterdam, Netherlands
    There are lots of really great mods coming out of really young modders atm which is very impressive. Keep up the good work mate.
    [D]ark[A]cid
    [D]ark[A]cid Member
    Nov 2, 2005
    144
    im sweet 16 fellas, just got my learners :) and lookin for my first car to do up too :thumbup:
  17. brodsta
    brodsta Member
    Nov 26, 2004
    987
    QLD
    lol, Nice 'little' gain there. :thumbup: :leet:
    Good work so far. Interesting to finally see some blowholes without the iconic lip. :)
  18. Kiba
    Kiba RIP Lest we forget!
    Jun 21, 2006
    685
    Nadi Ali, Helmand
    are those side pannels steel or aluminium? usually its steel hey. how long did they tale to sand? Nice mod :thumbup: and good luck with the car. hope to see a work log in the motoring forum. :)
  19. ener
    ener Member
    Dec 23, 2005
    3,620
    Gold Coast
    :eek: congratz on the L's ( i got mine a week ago) woo go the underagers, yeah good mod i was also reading it on bit-tech, because you updated that before ocau lol :D :thumbup:
    [D]ark[A]cid
    [D]ark[A]cid Member
    Nov 2, 2005
    144
    Thanks for the comments guys, they are all really appreciated :)
    yeah they are steel, and they took about 5 mins max each, using 80 grit on that sander. (I borrowed the sander off my stepdad, and OMG it is soo powerful, I don't think I can give it back :eek: )
    and yes there will be a worklog for the car :D
