Project Code: Tabeee MK 1
Discussion in 'Modding Worklogs' started by Bismar, Jul 5, 2008.
  1. HELL_HOUND
    HELL_HOUND Member
    Feb 26, 2007
    39
    Perth, WA
    +1 for support, this should be great!
  2. FranchiseJuan
    FranchiseJuan Member
    Aug 15, 2002
    3,172
    Somewhere Exotic
    Hay mate this looks awsome!!! Oh and I got here via engadget, so that is double awsome!
  3. matarael
    matarael Member
    May 11, 2003
    576
  4. Constructacon
    Constructacon Member
    Nov 27, 2004
    231
    Brisbane, QLD
    You're also on hackaday too. Go go OCAU.
  5. glasnt
    glasnt Member
    Aug 9, 2004
    3,793
  6. Kozzie
    Kozzie Member
    May 16, 2005
    559
    i hope you make it to the finish line buddy looks far to complex for anything i could ever hope in achieving good luck. maybe im looking to far into it but maybe show it off at the modding websites get some sponsorship :D
    Bismar
    Bismar Member
    Jan 28, 2006
    245
    OCAU Virtual Slumps
    Holy crap, i'm not sure wether to shoot or shake the hand of the person who referred this mod to those two sites, it seems that i managed some 11k views in just 12 hours 0_o. Now i feel obligated to hurry up with the mod lol.
    Anyways stay tune for more updates tonight, gotta buy some JB-Weld from Super Cheap Auto first.
    Right now there's 10 members online and 110 guests and 109 people are viewing the modding forum :p Hope Agg doesn't shoot me for the extra traffic this site has gotten :) Don't suppose you have a traffic chart Agg?
    Bismar
    Bismar Member
    Jan 28, 2006
    245
    OCAU Virtual Slumps
    Heh, thanks for your support, but this isn't exactly complicated, due to the lack of certain power tools, disc/belt sander and a circular saw, this project is more of a test bench for my second Tabeee mod which is being planned as we speak :).
    Bismar
    Bismar Member
    Jan 28, 2006
    245
    OCAU Virtual Slumps
    Ok this is annoying, just called up the nearest Bunnings, Kmart, Repco, Super Cheap Auto, Home Hardware stores and they all don't stock J-B weld.........
    Fun anyone else in Melbourne know where to get some?
  10. Ultra PeePi
    Ultra PeePi Member
    Feb 14, 2002
    316
    jb weld is just a brand of epoxy isn't it? just pick any other epoxy glue that suits.
  11. Agg
    Agg Lord of the Pings
    Jun 16, 2001
    33,195
    A Reported Post Near You
    Many charts, not many public tho. :) Traffic is good, btw. I submitted this thread to reddit and digg last night also, doesn't seem to have been very popular there tho. Plenty of other blogs linking it however.
  12. Paul Warren
    Paul Warren Member
    Jul 15, 2002
    2,901
    Melbourne, Victoria
    Nice work fella - keep us updated.
    Keen to see how it works out!
  13. aamp
    aamp Member
    Jul 8, 2008
    4
    Noob
    Like the mod mate. I've been wondering whether it would be worth turning my 701 into a slate too. My idea was to attach the screen bezel to the bottom section in place of the keyboard bezel. It looks like it should fit fine. The hinge plastic would need trimming and the lack of screw holes would be a problem - maybe some nice looking tape would do the trick - chrome tape... It'll look like a big iPhone then :D
    - What OS do you intend to install, XP or Vista?
    - Have you got a place for a stylus in mind (if you intend to take notes etc)?
    I would require a keyboard every now and then and the XP TIP isn't very good for finger input. Have you seen a good soft-keyboard to replace the XP one?
    Cheers!
    Bismar
    Bismar Member
    Jan 28, 2006
    245
    OCAU Virtual Slumps
    Nope, a little different as mentioned in my updated post.
    Worklog updated in 4th post. Stay Tuned for more.
    Bismar
    Bismar Member
    Jan 28, 2006
    245
    OCAU Virtual Slumps
    Good luck with your mod, you'll never know till you try! I hope i will inspire more people out there, as there is so much untapped potential in the touchscreens you can buy. As for a keyboard you can simply buy a rollable rubber usb keyboard.
    And for an OS i will be using eeebuntu.
    Stylus location is currently a secret :)
  16. Wshlist
    Wshlist New Member
    Jul 8, 2008
    1
    2mm nuts
    Wanted to mention in regards to the 2MM nuts/bolts, you can find those not at the hardwarestore but in electronics stores I found, just in case someone is looking for some, somehow a person tends to look for such in hardware stores I found even though they are most often used in electronics, but it seems a number of electronics stores sell them but very few hardwarestores, at least in my part of the world.
    Bismar
    Bismar Member
    Jan 28, 2006
    245
    OCAU Virtual Slumps
    Jaycar is an electronics store :)
  18. slamaa
    slamaa Member
    Jun 1, 2006
    2,063
    Reservoir, VIC
    Very nice Bismar, the black looks all nice an flush now with the bending machine you made :thumbup:
  19. Sureshot
    Sureshot Member
    Mar 15, 2002
    1,156
    Wow, this is looking even more awesome by the day. Take careful measurements of the build-up process, you will be able to sell more of these when it's done.
  20. aamp
    aamp Member
    Jul 8, 2008
    4
    Thanks for the encouragement Bismar, I'm looking forward to getting my hands dirty even on such a small scale. I'm assuming then that the touchscreen will just be used to control the mouse in eeebuntu? Or do you use touch enabled software of some sort?
    A rollable k/b would just be a hassle to carry around. I'd rather use an on screen keyboard of some sort. Or maybe I'll move the screen up and mod a little thumb-board in portrait mode (like the Wibrain UMPCs).
    Now to pry the eee pc from the wife...
