Project - Facelift and Clean Air Mod
Discussion in 'Modding Worklogs' started by Jolly-Swagman, Sep 12, 2008.
  1. Jolly-Swagman
    Jolly-Swagman Member
    Jan 25, 2008
    239
    Victoria, STH Gippsland
    Another Project Mod by Jolly Swagman
    This another of my Mods to my Old P4 Rig that will be mainly a total Facelift for the Case
    and the introduction of an Air Filter of the side intake for Clean Air ( No Dust Bunnies! )
    The Case will have the rear 80mm exhaust fan outlet enlarged to accommodate
    a 120mm exhaust fan
    The side intake ( Done on previous Mod ) will incorporate an Air Filter
    with 120mm intake fan
    The whole Case once stripped down, will inside and out will be Repainted in a
    Charcoal Gray Metallic Gloss Enamel and then Clear Coat Gloss Enamel
    The Old P4 Case
    (actual pic is slightly old as didnt have removable HDD caddy
    or second DVD drive or Floppy Drive)
    Also had better case wiring management​
    After Stripping Down System then Reconnected up on my testing desk, so as not to interrupt with Folding@Home
    Now onto the Project
    Tools used
    Jigsaw , Metal Files , Drill & Drill bits , Screwdrivers , Wet n dry Sandpaper
    Materials used
    2 x Cans Charcoal Gray Metallic Gloss Enamel
    1 x Can Clear Coat Gloss Enamel
    2 x 120mm Case fans
    1x 80mm Case fan (Blue LED)
    More Zip ties for cable management
    Blue Painters Masking Tape
    2 x 70mm M5 Thread screws & M5 Nuts
    2 x 4mm self tapper screws
    1 x 150mm diam Sheet metal
    1 x HP6 Air Filter 150mm x 50mm
    (see pic below)
    HP6 Air Filter
    After Cutting Rear 120mm Exhaust hole and preparing stripped down case for Painting
    it was on to the Painting, and the Results can be seen below.
    Two coats of Charcoal Gray Metallic Gloss Enamel and then
    Two coats of Clear Coat Gloss Enamel
    with a light Wet n Dry sanding between coats
    Case Shell
    Rear case with 120mm Exhaust cut out
    (Looks allot better than the picture as Flash makes look a little washed out..)
    More to come in next Post
    Jolly-Swagman
    Jan 25, 2008
    239
    continued
    Motherboard Removable Tray
    Case Shell with M/B Tray in Place
    Left Side Widowed Panel with 120mm Intake Exhaust
    Right Side Panel
    Front Panel
    (still masked on area down sides of Panel where Gunmetal Plastic
    to offset and Highlight Charcoal Metallic )
    HDD Cage
    ( with mounting at bottom for the 80mm Blue LED fan)
    Front Panel Bay Covers
    and 150mm Disk for Air Filter cover
    Here is a Close Up shot of the Paint Colour
    More to come next Post
    Jolly-Swagman
    Jan 25, 2008
    239
    Update 08/28/2008
    Another Project Mod by Lolly Swagman
    continued
    All the Hardware Re-Installed
    CPU - P4/HT 2.8GHz | M/B GA-865PE1000G Pro | DDR-400 2Gig|HDDSata200Gig + 80Gig IDE | PSU Kmec 500W Cool-n-Silent/CPUCoolerZalmanCNPS7000B-Cu
    120mm Rear exhaust Fan and 80mm Blue LED Fan on HDD Cage
    Front Angle Left side View
    Front Angle Right side View
    Windowed Left side View
    Close-up Window & 150mm Air Filter
    150mm HP6 Air Filter on Intake 120mm Fan Deep Cool High Performance
    SF-1200 1300rpm 44.71 CFM Hydro Bearing
    Rear View
    Rear 120mm Exhaust Fan with Hand made custom Fan Grill
    Conlusion
    Overall I think this project turned out better than had expected too, and gives
    a fresh new outlook to the Old P4 Rig.
    this Rig now manly used for Music /Video Archive, Surfing Web, Mail,
    Network Backup, Canon Photo Printer for Network,
    and of course Folding@Home.
    Overall Temps are pretty Good CPU @ Idle 28/30C and Load 42/46C
    HDD's Sata @ 22C IDE @ 30C & Load 30/32C(Sata) & Load 36/34C(IDE)
    Jolly Swagman
    Jolly-Swagman
    Jan 25, 2008
    239
    And further reserved content
  5. MrSmoke
    MrSmoke Member
    May 22, 2008
    2,368
    NSW, Blue Mtns NizzleBiX
    a Pentium 4 2.8GHz is hardly a v8 :/
    otherwise with a few more mods it could look tough
    if you really wanted it to be less dusty inside the case i would try to block as many holes as possible to make the only air intake at the air filter to filter all the air, but then you might have heat issues
  6. DeejW
    DeejW Member
    May 18, 2008
    1,946
    Margaret River WA
    Lol that looks ridiculous. Sorry just my opinion :p
  7. Akh-Horus
    Akh-Horus Member
    Feb 8, 2008
    10,617
    Western Vic
    Needs a V8 badge on the case.....havent seen a box with an air filter like that one it.
    All credit to the Op for having a go, thinking outside the square and being gutsy enough to put the pics on the net. :thumbup:
  8. TMM
    TMM Member
    Mar 29, 2005
    7,488
    If you had a lower profile GFX card you could probably fit the filter inside the case :).
  9. fergusb
    fergusb Member
    Jul 16, 2008
    193
    Its pretty cool. In my opinion though the old case was cooler...
  10. rainwulf
    rainwulf Member
    Jan 20, 2002
    4,213
    bris.qld.aus
    i would like to know exactly how much air is coming through that filter. A 120 mm fan, and all computer fans arent especially powerful in this regard. The filter would just be way to restrictive to proper airflow.
  11. Madchimp
    Madchimp Member
    Aug 26, 2007
    2,453
    Heybridge, Tasmania
    Good on ya mate :thumbup: I think it looks kinda cool :D
  12. Kozzie
    Kozzie Member
    May 16, 2005
    559
    hay dude thats a awesome idea when i first saw this i was amazed i have not tried it.
    im really thinking of giving something simular a go did you just come up with this idea yourself or is there a air filtering forum i havent visited yet? if by yourself how does it perform pros/cons how would i go about testing the actual airflow once i have wacked a few of these puppys on my pc ? i got a front 120 thats dieing for this.
    just relooked at it.
    can u make it so the filter just screws on and off for ease of cleaning ? how dusty has the filter goten allready?
  13. Invader_Stu
    Invader_Stu Member
    Feb 24, 2004
    761
    Haha, I think this is cool mate - huge improvement over what you had to start with. Does it actually stop dust from getting inside or is it mainly cosmetic?
  14. Doc-of-FC
    Doc-of-FC Member
    Aug 30, 2001
    3,244
    incoming air flow == restricted 120 mm
    outgoing airflow == partly restricted 120 mm + PSU fan
    as long as outgoing CFM is greater than filtered incoming CFM dust will be sucked in, due to the negative pressure differential.
    EG: Dust inlet
  15. Knobi
    Knobi Member
    Mar 21, 2005
    2,382
    Eeede-laide
    nice but???? big air filter? I wonder whether any air can actually pass into the case.
  16. oohms
    oohms Member
    Dec 22, 2005
    2,191
    Melbourne 3015
    Awesome idea.. how restrictive is the air filter?
  17. Supachiefauto
    Supachiefauto Member
    Mar 24, 2008
    47
    hahaha thats awesome man. 5 stars.
  18. BigDave
    BigDave Member
    Nov 12, 2007
    3,701
    ADELAIDE/5018
    Great idea, maybe try a chrome air cleaner from an auto shop
    Jolly-Swagman
    Jan 25, 2008
    239
    Thanks,,, It is not that restrictive,,, but after testing for the last week or so and with the weather being a little warmer last weekend I decided to try a second 120mm fan and airflow has increased quite considerably and also changed the rear exhaust fan to better 67CFM 120mm Fan and is quiet too.
    See above answer ( Air Filter is 150mm dia )
    Thanks .. Yeah it does stop dust getting in,, still as clean as when installed.
    Yes the Filter is easily Removable,
    the 2 - 65mm machine screws (centre Left/Right) hold the Filter to Case side panel
    With the second Fan now installed there is more than sufficient AirFlow
    If you put a plastic bag near it would be sucked around filter, and and from the Fan side enough to billow the bag full of Air.
    Yeah I was going to use the Chrome Air Cleaner cover that you can get for this one, but meant had to cut too much of the rear of, so didnt bother with it, Plus was an Extra $30
    Thanks Again for Looking and Comments !!
    JS
    Jolly-Swagman
    Jan 25, 2008
    239
    The part that you circled has actually got my Zalman fan mate controller mounted on the inside with the dial protruding through one of those holes and the Air actually comes out of,,, not sucked into,
    Also have since removed the Custom 120mm fan Grill on the rear Exhaust ( now has PVC Black Gutter guard as fan grill) and changed fan as mentioned above,
    Rear Exhaust 120mm Fan is Higher CFM than that of the Low RPM/CFM 120mm PSU Fan,, so Exhaust Air does escape with ease,
    Thanks for you Comments
    JS
