Project: Killer Penguin - murderMod TJ07
Discussion in 'Extreme and Water Cooling' started by converge, Jan 12, 2010.
  1. OP
    converge
    converge Member
    Aug 29, 2009
    2,316
    Yeah i had to drill the holes slightly bigger to fit the holders in. I can't remember off the top of my head what size holes they were though.
  2. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    If they're the same size as Stealth & EK res holders, they're M4. :)
  3. h2oxide
    h2oxide Member
    Dec 9, 2009
    3,754
    how many mm's?
    i need to know because ive got a stealth
  4. the_pessimist
    the_pessimist Member
    Sep 10, 2008
    3,055
    m4=4mm. m3=3mm and so on.
  5. h2oxide
    h2oxide Member
    Dec 9, 2009
    3,754
    Oh what a stupid Q on my behalf, sorry ahah
  6. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    If you tap the holes you can use much shorter M4 screws & not have to bother with nuts n' washers too :)
    I tapped my res holder holes & am glad I did. :thumbup:
  7. h2oxide
    h2oxide Member
    Dec 9, 2009
    3,754
    tapped as in threaded right?
    so you drilled to 4mm and tapped?
  8. alyxander
    alyxander Member
    Nov 2, 2006
    258
    where to buy your sumbeamtech internal power boards?
  9. Sil
    Sil Member
    Jun 20, 2006
    1,366
    Performance PC's :)
    converge
    converge Member
    Aug 29, 2009
    2,316
    You can buy mine if you want, I won't be needing it.
    Or performance pcs :thumbup:
  11. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,155
    converge
    converge Member
    Aug 29, 2009
    2,316
  13. radeon_freak
    radeon_freak Member
    Sep 19, 2007
    3,155
    True. Thought he was refering to the one with the 3pin headers on it. Is the other molex one Sunbeam also?
    converge
    converge Member
    Aug 29, 2009
    2,316
    Yeah they're both molex. The fan multi port is better as well as all the fan headers get 12v. With the bitspower one only 4 get 12v.
  15. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    The Sunbeams look better than the Bitspower ones but I don't like how they don't give you a lower voltage option...
    Someone buy my 480 damn it! :D
  16. h2oxide
    h2oxide Member
    Dec 9, 2009
    3,754
    Lower the price, maybe itll appeal more to fellow peers
    converge
    converge Member
    Aug 29, 2009
    2,316
    Nah $150 is a great price for it. It's the best performing rad for medium - high speed fans and they don't even make them anymore.
  18. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    Maybe I should just keep it?
    My build has taken the longest out of most on here already...
  19. h2oxide
    h2oxide Member
    Dec 9, 2009
    3,754
    So glad I got mine :O
    And yeah I heard, wasn't It just because they Cbf'd pretty much with the competition? Overall rad comparison result weren't differenciating from one another enough?
    Also yeah but that giant paint peeling off, D:
    converge
    converge Member
    Aug 29, 2009
    2,316
    lol I think Phil holds that honor and I don't think Joe has even completed one yet. I rekon it's worth getting the SR1 if you want to use low speed fans. I've had 2 buyers for my xchanger both for $150 so I think you should be fine. Just give it a little more time. I know bublik is looking for a 480 rad but he will most likely try and low ball you.
