Project Monolith
Discussion in 'Modding Worklogs' started by rainwulf, Jan 8, 2009.
  1. OP
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    I dont think i have posted it yet anywhere?
  2. Nitephyre
    Nitephyre Member
    Mar 31, 2007
    1,515
    ormeau@gc.qld.au
    Wow, haven't seen this before, but it looks like the central core for the Enterprise :O
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    My next job is to get the top done in the same poly, and the back to be covered in mesh like the front.
  4. auApex
    auApex Member
    Feb 15, 2006
    1,355
    Absolutely amazing! :thumbup::thumbup:
  5. schnappy
    schnappy Member
    Apr 23, 2008
    829
    3124
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    heh, im an idiot.
    I got the M2 tap from a model supplier. Hobbyrama.
    You can get them from specialist tools stores as well.
    EDIT: My bad, its an M2.
    well, whatever it is that requires a 2.5mm drill bit.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    Long time update.
    Remote box done.
    This box contains a power LED and Switch, which are integrated.
    Below that is the IDE light.
    Below that is 3 temp sensors.
    First one is ambient, second one is coolant hot side, third one is coolant cool side.
    I am going to change that though, there isnt enough of a temp difference between the hot side and the cool side of the radiator, so im going to use a sensor on something else, perhaps CPU block temp.
    Thanks to those sensors though, i have discovered that my radiator is overkill for this machine, so im going to wind the fans down a bit more to reduce noise.
    The outgoing coolant temperature is often only 1-2 degrees above ambient.
  8. mudmanor
    mudmanor Member
    Jan 3, 2009
    4
    DUDE!!!
    i saw you at lansmash man same pc it is soooo awesome
    please tell me if you did go to lansmash
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    I think i did... I cant remember.
    Im going to scoutlan this weekend though.
  10. brayway
    brayway Member
    Nov 29, 2008
    6,800
    New Zealand
    I was going to goto scoutlan, but kinda forgot, now i am working this weekend :upset:
    I swear i have seen this though, did you take it to the 30 something Hour Endurance lan At Caboolture in January?
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    Um.
    Possibly.. i lose track of whatever lans i visit.
  12. ageNtreachery
    ageNtreachery Member
    May 20, 2010
    4
  13. khoanna
    khoanna Member
    Jun 4, 2010
    58
    3975
    veryyy, alot of effort. well done mate.
  14. FarZK
    FarZK Member
    Jun 21, 2009
    909
    All dem waterblocks
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,238
    bris.qld.aus
    wow thread necro..
    totally new system now...
  16. Pic0o
    Pic0o Member
    Feb 6, 2003
    168
    'Murica, PA (state)
    Solid Solid states. Well played necro reply :)
    On the last page end. I am the ass who made this a new page. :) but a splash of fail.
  17. Panoram_Custom
    Panoram_Custom New Member
    Apr 30, 2014
    3
    This is amazing! I love it. True modding not just cash spending:D Well done
  18. d33g33
    d33g33 Member
    Dec 28, 2012
    180
    This gives a whole new meaning to 'built, not bought' amazing, I almost can't comprehend everything that has gone into this...
  19. Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    Melbourne, VIC, 3127
    Why no more tube spaghetti? It was so cool before :(
    Also is that 2 sound cards I see?
    Surely 6 SSDs is a little bit overkill. :shock::Paranoid:
  20. c_hegge
    c_hegge Member
    Feb 17, 2012
    492
    NSW
    Both builds were great. love the use of an air-con coil.
    I also love the use of the larger-than-standard Dell PSU. Contrary to popular belief, those higher end Dell PSUs are built like tanks. It isn't by any chance a H750P-00 is it? I have one of those in my stash or spare parts. It's built so well that I can't bring myself to toss it, but it doesn't fit into any of my cases :( (other than my old Antec 1200, which has an even more bulletproof also rather giant Delta DPS-750CB)
