Project Monolith
Discussion in 'Modding Worklogs' started by rainwulf, Jan 8, 2009.
  1. Crash Dummy
    Crash Dummy Member
    1,756
    Newcastle, NSW
    rainwulf
    Thank you very much for that feedback. I'll hit my local hobby shops up again and see if I can actually get someone to serve me who has some idea.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    the hobby shop i went to has a whole variety of brass, copper, aluminion and stainless steel stock. Square section, pipe, etc etc.
    This is Hobbyrama in stafford city, and it has a tonne of stuff.
  3. Crash Dummy
    Crash Dummy Member
    1,756
    Newcastle, NSW
    Cool thanks dude. I got some from my local as well eventually. Frontline Hobbies. I think it's 5/32 tube and connects beautifully to the RC fuel tube. I've now made a block for my northbridge in the same style as your own blocks as per the home made waterblock thread. I'll post a little tip in there that some people might appreciate. :)
  4. Arbite
    Arbite Member
    May 18, 2008
    1,037
    SA
    How are the TT pumps going, they have a tendancy to fail.
  5. Pipster
    Pipster Member
    Sep 23, 2008
    584
    yea thats what i was thinking, why the did u get tt pumps? danger den are the same price
  6. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,449
    This is just insane man nice job. Must weigh a lot anyway of weighing? and how much liquid does it hold?
  7. Laggy7
    Laggy7 Member
    May 19, 2005
    353
    adelaide
    just utterly amazed, when i first saw the split system air con, i thought ah yeah thats a good idea, but what youve done with it is AMAZING! all that copper welding, crazy manifold, fabrication and excessive waterblocks are awesome!
    glad you also went ahead with the UV lights, done that with my watercooling setup years ago. youve eventually got to put sides on it and finish it off!
    OCAU
    Engadget
    Whats Next: Atomic MPC - full writeup?
  8. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,449
    I can't believe this was included in the 10 most ugliest mods i reckon this mod is amazing.
  9. N1zmo
    N1zmo Member
    Apr 25, 2005
    608
    Perth, 6065
    Function over form.
  10. ford ftw
    ford ftw Member
    Jun 25, 2008
    1,449
    Very true.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    Pumps going well!
    I so shouldnt have posted this until it was finished :(
  12. Pic0o
    Pic0o Member
    Feb 6, 2003
    168
    'Murica, PA (state)
    Water Pr0n
    I nominate rainwulf as the king of Water Pr0n. As mentioned many times, your dedication to Ultra-blocking is unreal.
    Sweet build, even more so as the AC in the Office is broke today, and my Core 2 Duo (Office Rig) is most likely crying. :sick:
  13. Spectre8
    Spectre8 Member
    Sep 18, 2007
    14
    Melbourne, Australia
    Rainwulf, don't stress about any of the negative feedback mate - when someone goes to put together a list of uglies - it's almost exclusively going to be about the "different". Yours is certainly that! See how much positive feedback there is here... you're doing something right!! :)
    Awesome work there pal, and I can't wait to see how it ends - but happy to see the work in progress shots too! :) Very cool!
  14. 4wardtristan
    4wardtristan Member
    Apr 9, 2008
    1,181
    thats amazing! looks like alot of hard work went into it...nice work.
  15. MWP
    MWP Member
    4,632
    I have had epoxy go soft due to the additives in coolant as well.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    Update!!
    I finally got the sides ordered, and they have arrived. Due to cost constraints, im going with a special plastic aluminum ply construction for the case sides, so you wont be able to see in the sides. I just cant afford the over 100 dollars for a piece of clear plexi/ABS that will cover the side of the case.
    I got the plastiply for free, so its going on.
    I also managed to locate myself a nice 9600Gt and i was going to put it into the system for Physx support so i can play mirrors edge with all the cool things. Some damn bug between ATI and Nvidia makes that an epic fail. BSODS, something to do with catalyst and forceware drivers.
    On a side note, the ageia PPU does work in mirrors edge, and its awesome, but due to some epic fail between ati and mirrors edge and physx, ati+ppu= super slow. BAH.
    My speaker system died, so monolith is kind of on the back burner while i design the speakers and amplifier. 5 by 50watt and 1 by 200 watt amplifier module in one block. I shall call it the tower of terror or something. 4 torroid transformers, the works. Thats a different worklog however.
  17. RevIt
    RevIt Member
    Jan 30, 2009
    23
    Ummm, to have PhysX enabled BOTH cards have to be Nvidia.
    Cheers
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    No, you can run ati and nvidia physx. plenty of people have done it.
    I actually had it working. Its just that as soon as i did anything involving graphics, the machine would BSOD.
  19. Arbite
    Arbite Member
    May 18, 2008
    1,037
    SA
    Pics of new side panels?
  20. Skobb
    Skobb Member
    May 5, 2008
    1,237
    Adelaide, Tea Tree Gully
