Project Monolith
Discussion in 'Modding Worklogs' started by rainwulf, Jan 8, 2009.
  1. qnutnut
    qnutnut Member
    Feb 25, 2009
    173
    WOW.... Snakes & Ladders ?!?!
  2. alch
    alch Member
    Oct 9, 2006
    1,684
    What the FUCK.
    That is all.
  3. -Toast King-
    -Toast King- Member
    Mar 21, 2007
    28
    The Moon
    Will this do minesweeper, yes?
  4. Sandman331
    Sandman331 New Member
    Mar 12, 2008
    9
    How quiet/noisy is it?
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    Update:
    Just finished a prototype temperature controller that measures the difference between ambient and coolant temp, and runs the radiator fans to keep the difference down.
    Very simple, using two thermistors, an op-amp, and a mosfet.
    The circuit has variable resistors that can vary the gap between the ambient and wanted temperature, and gain control that adjust how fast the fans speed up to reduce the difference.
    The fan is controlled linearily, so no funky PWM here. Wouldnt be that hard to implement, but for now, its just going to be a linear control. There are 4 fans to control, so if the mosfet gets really hot, i may just watercool it...
    hehehe
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    Fairly quiet, the fans are only running on 5 volts, and with my temperature controller, will be even quieter, unless im gaming, where they will speed up automatically.
  7. FiftyOne
    FiftyOne Member
    Jan 25, 2009
    17
    Circuit diagrams?
  8. Skobb
    Skobb Member
    May 5, 2008
    1,237
    Adelaide, Tea Tree Gully
    I second that :)
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    Well i have moved the temp control over to PWM.
    Analog linear control is such a pain in the ass :(
    I have also put some new mesh on the front of the machine, and reached my goal of a stable good overclock.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    NEWS NEWS NEWS
    PWM temperature control is in beta stage and being tested now.
    I am not sure if its sensitive enough yet, it doesnt speed up that much under load.
    But some testing will see how it goes.
    but the real news is i finally located the side panels!
    Smoked POLYCARBONATE!
    Not just any perspex, but real tough polycarbonate.
    I have two pieces, and its fairly large, so there will be enough left over for the top, and any other bits i want to "hide" behind smoky dark perspex.
    here it is testing on the UV watercooling.
    Flash is on, so it actually looks a lot better then that.
    and with UV off.
    YAY!
    I hopefully should be able to cut it and fit it tomorrow!
    With flash off, you can barely see a thing apart from the leds on the motherboard, which im going to cover anyway.
    With the UV tubes off, its going to be hard to see whats inside.
    UV on, and all the cool stuff comes to light.
  11. Sir Hermit
    Sir Hermit Member
    Jun 24, 2009
    123
    Unreal! i love the choice of side panels, something different from your usual clear perspex:D!!
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    I didnt manage to get the polycarbonate cut today, the place was closed.
    Will try tomorrow.
    In other news, i have redone the pipes for the ram, hoping to get a bit of of an even cool, before it kept air locking.
    I have also put a particulate filter in, using mesh. This is to catch pieces of metal and plastic floating around in my loop due to the whole home made nature of the beast.
    This will also be a part of the bleed system that will all conglomerate into a water feature of sorts that will bleed coolant and air from all catch points into one place, and then be pumped back into the system.
    This will add more pipes, another small pump and other cool things. Its getting more complicated, which IS a bad thing, but i cant help myself. The more complicated, the more pipes, the more twisted up it will look on the inside.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    More News.
    I have redone my coolant system due to the silicone tubing going opaque, and very slightly porous. The pipes were going white, and I could always smell the coolant, even though there was no leaks.
    So i have moved nearly everything over to 4mm vinyl tubing that doesnt get affected by the coolant, and is totally transparent.'
    My polycarbonate is cut, and i will attatching them this weekend hopefully.
    Pics of the new tubes!
    They are thinner, and a bit tough, but it gives the machine a lot more organic look, which suits my theme of "jain technology"
    The UV cathodes will be going as soon as i find a good cheap source of UV leds.
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    WE HAVE SIDE COVERS!!!!
    Polycarbonate is fantastic stuff. There were at least 3 seperate occasions, including actually dropping the stuff on its edge that would have completely destroyed a perspex sheet.
    Polycarbonate just bounces.
  15. Nippy
    Nippy New Member
    Jan 9, 2008
    346
    Very nice indeed.
    Love it :thumbup:
  16. Razor540
    Razor540 Member
    Sep 5, 2007
    88
    Hats off... you've really gone all out! :thumbup:
  17. R3Dl2ULZ
    R3Dl2ULZ Member
    Oct 26, 2006
    1,238
    The Hills, Sydney
    Looks brilliant. Really impressive watercooling. It's gotta be one of the best mods I've seen in ages.
    I really like it how the polycarbonate is secured to the frame of the case, so rather than being a window it's a see-through side panel. The colour of it suits the style of the case well, especially with the UV lights on.
  18. MUTMAN
    MUTMAN Member
    9,124
    4109
    take the top off the optical drive and spin it 90o so you can see the disk spinning :thumbup:
    rainwulf
    rainwulf Member
    Jan 20, 2002
    4,264
    bris.qld.aus
    The drive is only there temporarily. Its coming out into the super mod thats still a secret.
  20. schnappy
    schnappy Member
    Apr 23, 2008
    884
    3124
    Actually I think I just read its work log... o_O
