[WORKLOG] Project Status: inebriation (Mega-itx custom case build)
Discussion in 'Extreme and Water Cooling' started by Pazzu, Jan 20, 2020.
Should I ditch the 360mm and
Poll closed Feb 3, 2020.
  1. Swap the rad with a thicker 360mm rad
    100.0%
  2. Swap the rad with a 240mm rad
    0 vote(s)
    0.0%
  3. I like it as is
    0 vote(s)
    0.0%
  1. Pazzu
    Pazzu Member
    Jul 16, 2015
    92
    2602 Canberra
    Custom case - Yes
    Custom cables - Yes
    Custom hardline watercooling - You bet
    Building a way oversized case for an itx setup???? Why not
    3900x
    x570i Aorus Pro Wifi
    1080ti
    ATX psu that I should really get rid of in favor of an SFX.
    Parts are shipping in, now to find a shop who can fabricate, drip and bend the single metal case.
    juzz86, mad_mic3 and Bolter01 like this.
  2. Will S
    Will S Member
    Aug 15, 2003
    5,371
    Coniston (Wollongong)
    way to go...nothing beats a nice big case with heaps of room to build in but worried it will cost a small fortune
    SFX is for small form factor cases, while ATX is for regular ones and since you have a big one then no reason
    you may be better to get a 2nd hand large case and mod the hell out of it ( and I do have one very old one in the garage but shipping doesnt make it cost effective )
  3. juzz86
    juzz86 Member
    Nov 15, 2013
    1,342
    Forth, NW TAS
    I was thinking SFX power supply, relocate 360/280mm radiator underneath the shroud with it? Retain the cooling power, lose the vertical height? I like the design a lot, but it's a lot of height for ITX maybe?
    Rotate MB 270 degrees, put I/O inside the front shroud thingy (make it a bit thicker). Res beside motherboard - retain long GPU support, pocket rocket.
    Pazzu
    Pazzu Member
    Jul 16, 2015
    92
    2602 Canberra
    Yea, I think it is too tall, did a mock up.
    Production cost should not be too difficult, the design I had in mind was to have it be created with 1 sheet of material, whatever it may be that I will decided on.
    ACM panels would be really easy to work with without sacrificing looks.
    I originally wanted to go with a 2U psu as my mate had one lying around
    I really should invest in an SFX PSU, not sure what I didn't pull the trigger tbh.
    Could justify spending on a custom case from ground up
    Could justify expensive wc parts
    I really should get an SFX, least an SFX-L
    mad_mic3 likes this.
    Pazzu
    Pazzu Member
    Jul 16, 2015
    92
    2602 Canberra
    Ver 2 progress.
    Still going to stick with the ATX PSU, the height and length of the rad makes it not really worth getting an SFX.
    mad_mic3, juzz86 and Bolter01 like this.
    Pazzu
    Pazzu Member
    Jul 16, 2015
    92
    2602 Canberra
    Took a while for me to decide how the cables and piping might run,
    but so far we have an accurate flat sheet drawn and ready to get some prototypes running!
    The top panel still gives me room to articulate and get a nice minimalist design on it.
    [​IMG] [​IMG]
    juzz86 likes this.
  7. juzz86
    juzz86 Member
    Nov 15, 2013
    1,342
    Forth, NW TAS
    Is that modular power extensions at top? That's an awesome idea, buy an extension kit and change colours at will :thumbup:
    Should end up very tidy :thumbup:
    Pazzu likes this.
    Pazzu
    Pazzu Member
    Jul 16, 2015
    92
    2602 Canberra
    Thats a very cool idea!
    and no thats not the plan, never thought of it that way tbh, something for the next build!
    This one I need the custom lengths to make it neat.
    The holes at the top are for the cables to individually go through.
    inspiration was from the bit tech trident royal build.
    zwatton and juzz86 like this.
  9. juzz86
    juzz86 Member
    Nov 15, 2013
    1,342
    Forth, NW TAS
    Ahh gotcha - that's a bloody clever idea too. I really like the organised look of combed cables, that build in your post is very cool :thumbup:
    Pazzu likes this.
    Pazzu
    Pazzu Member
    Jul 16, 2015
    92
    2602 Canberra
    Things are moving slowly for now.
    Getting quotes and seeing what results i can get from shops around the act
    But a bit of testing is being done on the side.
    Im hoping that the 360mm can keep the 3900x and 1080ti happy
    juzz86 likes this.
  11. juzz86
    juzz86 Member
    Nov 15, 2013
    1,342
    Forth, NW TAS
    What colour are you going with for the GTs mate?
    Pazzu
    Pazzu Member
    Jul 16, 2015
    92
    2602 Canberra
    Going for white.
    Going to match in the sleevings that i got (still haven't shipped- bloody aust post sometimes)
  13. juzz86
    juzz86 Member
    Nov 15, 2013
    1,342
    Forth, NW TAS
    Lovely. They'll be the best performing Swiftech Helix fans ever made :p:thumbup:
