[WORKLOG] Project TJ07: High Contrast
Discussion in 'Extreme and Water Cooling' started by h2oxide, May 25, 2010.
  1. Azuras
    Azuras Member
    Nov 20, 2009
    578
    jeez, havent you finished this yet? i threw a case together in the last couple of days, now stop talking to me on MSN and work fool!
    and gimmeh your elbows......
  2. converge
    converge Member
    Aug 29, 2009
    2,316
    Looking good man and good luck with the build. Let me know if you need any tips with modding the case or what not :)
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    will do man, your help has been appreciated so far, i keep using ur builds pics as reference :)
  4. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    Ditto, penguin helped me heaps with positioning of parts etc. & Jay always helped me with any questions, sad to see that one being sold orff... :(
  5. jam3sh1ll
    jam3sh1ll Member
    Dec 11, 2009
    84
    Going to be a very wicked TJ07, cant wait for more :)
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Cutting soon
    This is what im planning to do with midplate
    Ideas for how the midplate is going to be cut?
    I was just thinking drilling holes all next to eachother and then dremelling the little curves left off?
    Any better/other suggestions?
  7. wookiie
    wookiie Member
    Nov 7, 2009
    663
    Western Sydney
    Linky I use 1 of these it's great on .5 sheet metal and 1.5mm alloy
  8. Omnomnom
    Omnomnom Member
    Oct 7, 2009
    278
    It's deceptively strong.
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Good idea, but Ive got 2mm alloy here and I wont/dont have access to that (broke, and i dont live in sydney)
    Any other ideas?
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    does it leave shit behind which is hard to clean off?
  11. Omnomnom
    Omnomnom Member
    Oct 7, 2009
    278
    Nope, I'm not too sure how to describe it, unlike some double sided tapes that are "foam-like" and generally break up, this is almost silicone like and holds itself together very well.
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Whats it called/where'd you get it from/what thickness's does it come in?
  13. Omnomnom
    Omnomnom Member
    Oct 7, 2009
    278
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Im guessing you got a pretty thin one so it doesnt push the radstand along with the fans and rad too far out of alignment with the tj07 side grill
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    bump to this question
  16. Omnomnom
    Omnomnom Member
    Oct 7, 2009
    278
    It was probably ~1mm thick, without stretching it.
  17. assembly
    assembly Member
    Oct 8, 2004
    8
    Jigsaw with a high speed steel blade and mask it all up. Ii you want it to be round at the ends do those first with the hole saw and then cut the straights.
  18. denyer86
    denyer86 Member
    May 19, 2009
    43
    Stick with your idea of drilling a series of holes, but just use a file to clean up the leftover bits. Also make sure you centre punch the holes, that way you don't have to worry about the drill bit running away from where you're trying to drill.
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    hah yeah obviously, Im a noob, but no idiot :tongue:
  20. Azuras
    Azuras Member
    Nov 20, 2009
    578
    Yoink
    saving you down in mah sig
