[WORKLOG] Project TJ07: High Contrast
Discussion in 'Extreme and Water Cooling' started by h2oxide, May 25, 2010.
  1. OP
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Hate you so very very much
  2. BigDave
    BigDave Member
    Nov 12, 2007
    3,705
    ADELAIDE/5018
    :lol::lol::lol::lol:
  3. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    Two holes at each end for rounded ends then cut along each side with a jig saw or Dremel.
    Coarse files then fine files & or Dremel grinding & or sand paper attachments. :thumbup:
    Or get it laser cut, just make sure you tell me where you got it done! :D
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Update
    Pics of the workshop just so you have an idea of what sort of machines are there
    I realise its mostly woodwork tools as I didnt bother going into the metalwork one, (I only needed a jigsaw/drillpress both of which were in the woodwork room)
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Second Update
    Before/after pics
    Ended up drilling 2*12mm holes and cutting it out using a jigsaw
    Marking it up using pencil :lol:
    After pics (in a different room as I forgot to take pics straight after)
    Will be p/coating shortly when I have some money/time (p/coaters only open weekdays and its a 40min drive one way)
  6. Rory K
    Rory K Member
    May 13, 2009
    2,261
    Melbourne, 3131
    Wow, that's a huge distance! I think you mean 40km?
    Liking what you've done so far. I think it would have been easier to cut through the bit that stands up, mine is like that (2nd hand, came like that), makes it easier to route the cables as you don't have to thread them ;)
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Thanks
    I meant 40m as in minutes
    You mean like converge's ex TJ07?
    Thread them? You mean like put them through that hole? Idm at all, and it provides for a neater look
  8. Rory K
    Rory K Member
    May 13, 2009
    2,261
    Melbourne, 3131
    Oh right :lol: that works out about the same I think (avg. speed of 60km/h = 1km/minute so 40km = 40minutes :p)
    Yeah true. Although you're not going to be seeing it all that often :lol:
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Im anal :)
  10. da_truest_moo
    da_truest_moo Member
    Feb 10, 2010
    174
    Bit late but thanks for the photos of the fittings, they do look petty schmick dont they. Better than black sparkle IMO.
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Definately mate!
    No probs
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Small Update
    Drilled out holes on mobo tray for stealth res, it fits now
    Pics aren't really worth it as it was literally a 2 minute job
  13. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    Nicely done mate, wish mine had turned out that nicely. :thumbup:
    Never mind the extra length you'll appreciate it when passing sleeved cables through there. :)
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    yours looks fine too mate
    although a little short, mines longer so i can put more shit through it
  15. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    Ha thanks, it was my very first attempt at using power tools & modding ever. :)
    The powder coating should hide the scrapes & scratches where I didn't tape. :thumbup:
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    I didnt use any tape :)
    And pretty much the same here mate
  17. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    Nice one, water cooling is a process of education & self discovery.. Enter ones own consciousness and journey within.... then without... then cut some shapes into metal....
    Ohmmmmm :leet:
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    *shoots ElBeasto in the foot*
    snap the fuck outta it man
  19. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    LoL.... then becomes an old hippy douche bag! :Paranoid:
  20. wookiie
    wookiie Member
    Nov 7, 2009
    663
    Western Sydney
    Did you do some substance experimentation in your earlier days???? :lol::lol::lol:
