[WORKLOG] Project TJ07: High Contrast
Discussion in 'Extreme and Water Cooling' started by h2oxide, May 25, 2010.
  1. Little Man
    Little Man Member
    Sep 4, 2008
    4,602
    3147
    hehe. not going your way today haha.
    I got my 480 feser brand spanking new and it comes banged an ddinged and i bought a feser 240 3rd hand without i spec of dust on it :p
    But yeah definitely complain to who you bought it from.
    Where was it btw? I thought nobody in Aus stocked feser anymore.
    PS: IF you really want that 920 that badly...
    you can buy mine.
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Sidewinders, no im not buying yours im getting a replacement
    I may just get the HWLabs SR1
    This quality is appauling
  3. the_pessimist
    the_pessimist Member
    Sep 10, 2008
    3,055
    I'd say for good reason.
    on a side note its not going to affect performance and your not going to be able to notice it since its down the bottom; your only concern would probably be resale value.
    ps what hdd cage are you planning on using for the hdds?
    I really like the look of the SR1. (hopefully they'll be much better quality)
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    The one hdd* Scythe Bay Rafter Combo
    Im simply not accepting a third hand quality item like that
    Its meant to be flawless
    h2oxide
    h2oxide Member
    Dec 9, 2009
    3,763
    Suggestions on a replacement Rad? HWLabs SR1? Thats the only other decent rads I see at Sidewinders
  6. Little Man
    Little Man Member
    Sep 4, 2008
    4,602
    3147
    Well that'd explain it.
    I strongly recommend against buying something as fragile as a rad (more specifically the fins) from overseas where its bound it get thrown around and probably dumped under shit load of boxes.
    Er...
    http://www.thekoolroom.com/index.php?route=product/product&path=41_43&product_id=109
    local ftw.
    EDIT:
    Just remember that the 5.25" bay covered take up the three 5.25 bay device mounting holes closest to the case so if you want to mount it all the way bay into the bay you have to remove the front cover or otherwise mount it vertical.
  7. Ka0sX
    Ka0sX (Banned or Deleted)
    Dec 28, 2006
    2,786
    Canadian in Australia
    Just grab a RX480 and be done with it
  8. Copie
    Copie Member
    Jul 24, 2009
    13,865
    Newcastle
    They are a good rad, i had one ages ago, cooled a dual PCB 295 and an C0 stepped I7 @ 4ghz very easily.
    Needs decent fans though, i used 2000rpm Ultra Kaze's personally.
  9. converge
    converge Member
    Aug 29, 2009
    2,316
    Don't get the sr1 unless you're planning on using sub 1000rpm fans, anything higher would be wasted on it. The reason you can't buy feser in aus is because they are no longer making the xchanger series rads. For 1850 gts you should be looking at a thermochill. For lower speed fans you should look at an rx360. For 2000rpm and higher you should look at a hw labs gtx.
  10. Ka0sX
    Dec 28, 2006
    2,786
    Jayy there is more to it then just there not making the xchanger rad anymore
    Gam was supposed to be the only distributor in Au then they went to PCCG then PCCg got sick of dealing with them because they were fucking pccg around so pccg gave up.. that's why they were no longer AVL in AU but still in USA
  11. Rory K
    Rory K Member
    May 13, 2009
    2,261
    Melbourne, 3131
    I think you might be thinking of the GTX, the SR1s are quite new, and supposed to be much better with low RPM fans. Plus they look sexy :weirdo:
  12. Copie
    Copie Member
    Jul 24, 2009
    13,865
    Newcastle
    Yeah thats what i was just thinking as well, i purchased it from chilledpc when they were still operating.
    Wasnt a bad radiator though. AussieRevhead would be able to tell you as he brought it from me for 60 bucks with the 3 fans from memory.
  13. dreamaxx
    dreamaxx (Banned or Deleted)
    Jan 28, 2008
    2,134
    Gold Coast
    Actually I'd say the XSPC RX rads are the best in terms of quality, performance and looks.
  14. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,600
    Melb
    Send it back and get a new one, u gonna pay shipping for ur new rad so why not send it back and get them to pay for shipping it back.
    My feser turned out 100%, just a case of bad luck i rkn.
  15. Ka0sX
    Dec 28, 2006
    2,786
    +1 :thumbup:
  16. converge
    converge Member
    Aug 29, 2009
    2,316
    For low - mediuam speed fans yes. For medium - high speed no.
    For best performance get a hw labs gtx and some 38mm sanyo denkis.
  17. mugga
    mugga Member
    Feb 15, 2002
    1,098
    Parramatta
    Quoted for truth.
    And get these fuckers if you don't give shit about noise.
    http://www.bjorn3d.com/read.php?cID=1663
  18. Ka0sX
    Dec 28, 2006
    2,786
    Yeah RX Series are good rads
  19. ElBeasto
    ElBeasto Member
    Nov 3, 2004
    2,906
    I never buy anything from Sidewinder any more, I ordered so much stuff from there and about %65 of it had small amounts of damage. When I told Gary about it first off he implied that I didn't buy it from his shop, second he implied that I used tools on the fittings I was complaining about.
    I swear that some of the stuff I bought from there wasn't new eh.
    Basically he just turned into a horrible little bean counter. Just don't shop there unless it's something virtually unbreakable like screws or brackets etc...
    I saw some fittings at Sidewinder that no one else had, so I just emailed Performance PC's to order them in for me. If I had of ordered them from Sidewinder, they would have arrived in a 'factory Seconds' condition & for the money we Aussies have to pay for everything basically, it's just not on.
    The paint job on the Feser rads is very thin, they claim it helps with heat transfer. Funny how it also keeps costs (for them) down. They're a decent rad but the finish on them is a weakness, I'm thinking of painting mine later on.
  20. zeropluszero
    zeropluszero Member
    Aug 6, 2008
    6,051
    3132
