Project Vicious-S, corsair air 240
Discussion in 'Modding Worklogs' started by Tomma_Liu, Jan 25, 2015.
  1. Tomma_Liu
    Tomma_Liu Member
    Jan 24, 2015
    18
    I'm new here, this is my new project.
  2. _slacker_
    _slacker_ Member
    May 25, 2003
    1,240
    hiding from census dude!
    love the btx conversion :lol::lol::lol: never thought of flipping it upside down. looks pretty good. :thumbup:
  3. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,265
    Nulkaba
    Looks sweet as, like the yellow fluid:thumbup:
  4. Paulie_AU
    Paulie_AU Member
    Nov 29, 2013
    3,463
    Really tidy build. Looks great and awesome to see rigid tubing being used properly.
    Well done. :thumbup:
    I really should go finish mine and put the orange pastel in..... so lazy.
  5. dewy
    dewy Member
    Oct 2, 2004
    966
    Australia
    That looks lovely man, I only wish I could find an affordable block for my graphics card ):
  6. the3coopers
    the3coopers Member
    Jan 7, 2012
    1,681
    Sydney 2151
    Great job on the tubing - looks absolutely awesome! :thumbup:
    However it would be a LOT more interesting if you didn't show us like 20 photos of exactly the same thing - you realise that we can rotate our heads or monitors if we want to see the same shot at 6 different angles. :lol:
    How about giving us images of some of the other aspects of the build? For example, how did you get those tubes so accurately bent?
  7. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,011
    Cheltenham VIC
    Nice! But I want a photo of the other side :D
  8. MSIINOZ
    MSIINOZ Member
    Apr 13, 2012
    33
    AT THE BEACH NORTH NSW
    Very nice build for a compact machine, What sort of temps are you getting?
    From what I can see both the front rad & upper rad fans are mounted in the push configuration (both exhausting/pushing air out of the case) which would = a lot of negative case pressure, Not a huge problem but the fans & the huge gaps around them would be more of a problem as in a loss of efficiency, In both push or pull configuration having the fans sealed off to the radiator helps drastically
    in the push configuration like yours the pressurised air from the fan would be hitting the radiator core & escaping out through the gaps around the fans rather than forcing ALL of the air through the radiator core
    Works the same the other way too, Fans trying to pull air through a radiator core will suck air around the side of the fan rather than through the core if there is gaps
    As mentioned its not a huge problem but maybe if you changed fans or sealed them off you could get better temps at the same fan speed or same temps with less fan speed & less noise too
    I will be running the same radiators on my new project, Checkout the fan shrouds I made>
    http://forums.overclockers.com.au/showthread.php?t=1155079
    +1, Some pics of the other side of the case would be great
    Tomma_Liu
    Tomma_Liu Member
    Jan 24, 2015
    18
    Yes, i will post some photos for the back later,lol
    Tomma_Liu
    Tomma_Liu Member
    Jan 24, 2015
    18
    yes, i will post the photos for the other side. lol. i have a lot work to do ...:D
    Tomma_Liu
    Tomma_Liu Member
    Jan 24, 2015
    18
    thanks for you reply, i know this problem. and the temp i got is ok,
    and also i only use 1 x 780 ti so the temp must be ok, the air flow from the back, i need design some cover for the back, only one problem is the noise . now i let the fans running under 1000, and the temp of cpu is around 35, gpu is around 42, use the furmark let the gpu overload, the temp will go up to 60, so i have to change the fans speed to 1500, so will be loudly , cause of i think put the fans like mine looks better.
    do you have any idea for me?thank you
  12. MSIINOZ
    MSIINOZ Member
    Apr 13, 2012
    33
    It would be possible to have some shrouds custom made to seal the Coolermaster fans but that looks like a lot of trouble due to the shape / design of the fans, It might be better to fit some different fans that are easier to seal off using simple flat shrouds
    You have a Corsair case so why not go with some Corsair SP120 fans?
    The template to make some shrouds can be found here>
    http://mnpctech.com/pc-cooling-fan-templates.html
    15mm fan spacing>
    http://www.mnpctech.3dpixelnet.com/picture_library/mnpctech_rad_template_15mm.pdf
    Using the Corsair fans would also allow you to add a bit more colour & I think it would give it that finishing touch without overdoing it>
    Read here>
    http://www.overclock.net/t/1367519/corsair-af-sp-fan-owners-club/40#post_21342726
  13. LostBenji
    LostBenji Member
    Oct 5, 2007
    6,076
    Up a tower somewhere....
    A little over-kill on the cooling but nice job, well done.
  14. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,011
    Cheltenham VIC
    GET OUT! you are not welcome here
    :lol::D
  15. Maghemi
    Maghemi Member
    Jun 6, 2006
    242
    Is there any chance of some shots of the pump power supply side?
