Proluma triple Monitor Mod
Discussion in 'Modding' started by terroristone, Apr 28, 2010.
  1. terroristone
    terroristone Member
    Apr 16, 2006
    2,208
    Melb 3030
    ok as always im very impatient so i have already modded the arm to allow them to fold im more, my camera plays up from time to time so some shots didnt come out that well...
    shows the arm and the lug in question
    You can either file like i did, or use a grinder, maybe even take it out on the road and use the concrete to "grind" it off if your desperate:tongue:
    Using a file only took around 3 minutes to do one side.
    All gone.
    Before....
    After.
    I thinks for the time it takes its really worth doing even before you try your monitors, i dont see any reason why they are even there really. i'd like to see Proluma make an upgraded spring for the middle monitor, and also 4-5 inch extensions for the arms, they could bolt in easy i think, wouldnt be hard to make and fit.
    Regards Andrew
  2. cyrax83
    cyrax83 Member
    Feb 5, 2005
    5,082
    hurstville, sydney
    excellent, good job.
    is that a 20|30|20 setup ?
    Did you have issues with the 30" weight like i am ?
  3. DeejW
    DeejW Member
    May 18, 2008
    1,951
    Margaret River WA
    looks like a 24" in the middle
    terroristone
    terroristone Member
    Apr 16, 2006
    2,208
    Melb 3030
    yeah it is, 2001fp | 3007wfphc | 2001fp, and no its no sagging like yours is, but i have looked into fixing the problem if mine dose start to sag. Try putting some washers under those screws dude...
    Andrew
    terroristone
    terroristone Member
    Apr 16, 2006
    2,208
    Melb 3030
    you asking for proof? or just being a nob?
  6. brayway
    brayway Member
    Nov 29, 2008
    7,550
    New Zealand
    will see if i require it when mine arrives, might have to go searching for dads files haha. thanks for posting this!!
  7. DeejW
    DeejW Member
    May 18, 2008
    1,951
    Margaret River WA
    hah no it just looked like a 24" next to the g15 but I forgot the g15 is a big keyboard
  8. roweysvn
    roweysvn Member
    Dec 22, 2005
    456
    Gold Coast / Brisbane
    I'd love to do a setup like this, but unfortunately my desk and where it is in the house just wouldn't fit it I don't think. Looks great though, well done.
  9. Dorz
    Dorz Member
    Jan 22, 2007
    1,816
    not sure if im right, but i believe it has something to do with not straining your eyes so much compared to working in the dark, but also not providing as much light that could annoy others...
    am i close? :)
  10. karltron
    karltron Member
    Oct 6, 2006
    76
    WI, USA
    In a dark room, staring at a bright rectangle strains the eyes. It's good to have the bright rectangle taper off by backfilling the area. This is especially true in cases of such enormous monitors. Perhaps owning a 30" indicates the user will spend a lot of time with it!
    The hard part is making it match the brightness of the screen properly. Some expensive TVs have backlights that try to even match the main colors being displayed.
  11. lionman
    lionman Member
    Apr 27, 2008
    2,880
    Perth,WA,Earth
    Can't you rotate the right hand monitor 180' so the dell logo isn't between panels?
    Would piss me off being there...
    Nice setup by the way:thumbup:
  12. millsy
    millsy Member
    Mar 31, 2007
    15,407
    I actually use a dark wall behind mine with a bit of lighting to balance it out, you can really tell the difference, it's nice.
    Also nice work on the mod OP :thumbup:
  13. Oktavius
    Oktavius Member
    Aug 13, 2001
    1,928
    Sweet, you wanna add some in game shots?
  14. ascl
    ascl Member
    Aug 13, 2009
    463
    Back lighting also helps the apparent black level of your screen, although to maintain the colour accuracy the light ideally needs to be white (6500k). More info here if anyone cares:
    http://www.avsforum.com/avs-vb/showthread.php?t=451527
    I have a bias light for my TV, its something I'd definitely recommend. I don't have one for my computer screen tho... maybe I should :)
  15. Koops
    Koops Member
    247
    Melbourne, Australia
    alarm screamer next to the network cable coming out the wall?
    ->[​IMG]
    terroristone
    terroristone Member
    Apr 16, 2006
    2,208
    Melb 3030
    Thank you!
    See Below
    Bazinga!
    Thanks for bringing that to my attention, when using the factory stands you can only rotate to the right, i put the new stand on in a hurry and didnt even think about it.
    i only have 4870 CF in this setup so no eyeefinity, might install softth and run some race games on here as i have since disassembled my racesim and have been having withdrawal's...
  17. Archy
    Archy New Member
    Jan 23, 2010
    1,312
    Glenhaven, Sydney
    My thoughts exactly. Driver restrictions? I love the ethernet cable coming from a whole kicked in the wall.
    terroristone
    terroristone Member
    Apr 16, 2006
    2,208
    Melb 3030
    no driver restriction, just factory stand restrictions, but has since been rotated the other way. that hole isnt kicked in, its punched in, cpf getting back there and screwing the wall plate on.
    Andrew
    EDIT : keep at it and i might just get back there and fix it!:tongue:
  19. Kosti
    Kosti Member
    Aug 19, 2001
    1,550
    What the span measurements, ive got a relative small area and would like to fit in 22 : 24 : 22 screens in a similar set up to yours, so keen to know the area I need to make this work at my place
  20. Aratahu
    Aratahu Member
    Jul 12, 2004
    573
    Melbourne VIC
    Great mod, it would work great in your setup with walls etc.
    The way I see it is that if pushed backwards or forwards too much, the whole thing might just topple over.
    However I tried pulling my own setup towards me, and I can testify there's not even the remotest of possibility that this would ever happen.
    I have a fair amount of space behind my own stand so a bit hesitant to try it. (I also have inquisitive cats, and a kid on the way.)
    One could probably construct a blocker for the backwards movement rather easily - i.e. just something flat/long & solid zip tied to the main arm in two spots and overlapping the extension so that it'd restrict backwards movement. For forward movement, the middle monitor would probably act as a natural stopper.
    I really wish Proluma could make arms that allow for a much greater forward travel play, yet still stop when moved backwards.
    My own setup: http://www.flickr.com/photos/jorgens/sets/72157623513054711/show/
