Python exception from module
Discussion in 'Programming & Software Development' started by 7nothing, Nov 24, 2019.
  1. 7nothing
    7nothing Member
    Feb 15, 2002
    1,466
    So I tried asking in python-forum.io but the mod who was kind enough to answer my question seems to have learning difficulties. New to python, done years worth of php.
    I'm using someone else's module: pdftitle, if it throws any exception, I want to quietly give up and move on to the next PDF.
    Code:
    import pdftitle
    FilePath = "c:\somepdf.pdf"
    try:
        PdfTitle = pdftitle.run(FilePath)
    except:
        print("an exception occurred")
    ...doesn't catch any of the variety of exceptions when pdftitle (or one of the modules it uses, getting a mix of pdfminer.pdffont.PDFUnicodeNotDefined and recursion limit exceeded for PDFs it doesn't like) throws one.
    I am seeing an "During handling of the above exception, another exception occurred:" in the exception. Is it that which stops my try/except from catching, something about the nesting? How do I make it shut up?
    7nothing
    7nothing Member
    Feb 15, 2002
    1,466
    Ok so I was properly retarded. ...actually drunk.
    Had commented out a chunk of the pdftitle run() function to pass the file name to it. Which worked when it worked, clearly didn't when it failed.
    Not directly related, but have to blame python, since it's a language based on indent (which should be tab, but it's 4 spaces, just ask Richard Hendricks) but the IDE doesn't support shift + tab?
  3. Quadbox
    Quadbox Member
    6,272
    so... use a better IDE?
    7nothing
    7nothing Member
    Feb 15, 2002
    1,466
    Point was, the Python bundled IDE is not optimized for Python.
  5. GumbyNoTalent
    GumbyNoTalent Member
    Jan 8, 2003
    7,972
    Briz Vegas
    python doesn't come bundled with anything, its not python language fault you installed a POS IDE, use test editor which meets your needs.
  6. becubed
    becubed Member
    Jan 16, 2002
    544
    Idle?
    7nothing
    7nothing Member
    Feb 15, 2002
    1,466
    Sorry you'll have to speak up, I can't hear you over the noise of the self-described python integrated development environment that was included in the install
  8. GumbyNoTalent
    Jan 8, 2003
    7,972
    Briz Vegas
    https://docs.python.org/3/library/idle.html?highlight=idle
    Well I'll be a mutha...er, what a piece of shit, but I suppose you use Windows Wordpad for writing all your documents as well so fair call.
    7nothing
    7nothing Member
    Feb 15, 2002
    1,466
    I didn't scroll all the way through the matches, is there one where it outlines why they wrote their own IDE without supporting the established shortcut for fundamental indentation?
    If I installed the wordpad toolkit and it created its own document association with wordpad, and that was flawed... I guess I wouldn't bother cos that's wordpad.
  10. neRok
    neRok Member
    Aug 19, 2006
    3,392
    Perth NOR
    Who cares. It's an old POS from when Python was really trying to be an all in one programming language. The established shortcuts probably weren't so established 20 years ago. Yet, if you look in the Format menu, you will see it has indent and dedent shortcuts, and you can change them in the options.
    Or, just install vscode like a normal person.
