Radiator Flow and temp sensors
Discussion in 'Extreme and Water Cooling' started by Sven76, Dec 17, 2013.
  1. Sven76
    Sven76 Member
    Aug 7, 2002
    1,386
    Bundaberg
    Ok so i have this radiator
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_297_1484&products_id=23505
    I have used the 2 top facing ports and have plugs in the 2 end ports i want to replace the end plugs with sensors. So am I right in assuming that there are 2 tanks in there and if I put a sensor on the end at the inlet side where the cpu pushes the water in and put a sensor on the outside where the radiator sends the water to the rez I will get incoming water temp and outgoing water temp?
    Do you like my paint skillz?
  2. Ratzz
    Ratzz Member
    Mar 13, 2013
    8,394
    Cheltenham East 3192
    As I understand it, and totally a noob myself when it comes to WC, the temp should be approximately the same no matter where you measure it in the loop. That would make a second temp sensor pointless.
    Sven76
    Sven76 Member
    Aug 7, 2002
    1,386
    Bundaberg
    What you are looking for is the term "Normalisation" and this is correct I am only putting 2 in as I am putting bling on the front of the case I have 1 sensor in Red for the incoming water to the RAD and one sensor in Blue for the outgoing water and I fully expect maybe a 1 to 2 degree variation. The loop itself still cools the water in the radiator so there will be a small difference just negligible in the grand scheme of things. Just trying to get the flow in my mind as i have other options for mounting if i need to. These ones will just be unseen completely.
  4. Jakusonfire
    Jakusonfire Member
    Jun 16, 2012
    512
    Newcastle
    Yes, it works fine. I have done the same thing with an XT45
    At idle I see about a 0.2C diff and about 0.7 at full load.
