Can anyone please help me I have just purchased FastDosBox from the pi store so I can play my old dos games and can anyone explain how to mount a drive in fastdosbox cause Raspian wheezy OS don't display drives names like A: D: C: etc etc so do I need to create some sort of separate partition on the sd card in order to mount a drive ,can anyone explain to how to get my games working , I have no problems using dosbox on my main pc mounting drives and playing is easy , I'm only new with using Linux so please don't laugh if this sounds like such a dumb question HELP REALLY WANNAA PLAY COMMANDER KEEN AND AND HERETIC AND LOL
Doesn't google work in Darwin? http://www.norisc-nofun.co.uk/docs/The_Black_Art_of_DOS_emulation_for_RPI.pdf
yes google works in D-Town but i been trying all day to get this working i been reading this exact guide and still a bit lost cause things wont work was hoping somebody had a simple answer to fix it but al good i will keep trying i think i need to read up more on how Linux works rather than diving straight in to something that i have no idea about ,
what would be nice if some one could send me a preconfigured sd card image so i can plug and play , but i learn nothing doing that way
Anything Linux based usually has a bit of a learning curve. Stick at it, you'll get a real sense of accomplishment when you get it working
I paid for this yet cannot work out how to download it. The Indicity client just doesnt seem to download it. Any help appreciated.
Lol that brings back my mandrake and redhat days, true as true there. Ah dam now i want one for syndicate
Not sure if this helps but here is my simple guide for setting up a pi from scratch: http://simon.fearby.com/blog/?p=1752
make a folder in you home directory that you want to have as your C drive in dosbox (/home/pi its the default folder when you press home in the file manager on the desktop) for this example ill assume you called that folder "dos" then within dosbox type mount c /home/pi/dos then swap to C: and away you go don't be surprised if its too slow to be playable though, rpiX86 can be a LOT faster but its a bit less compatible. overclocking the pi may help but its still pretty slow.
