Reciprocating Linear Actuator Thingy
Discussion in 'Electronics & Electrics' started by glenpinn, Jul 24, 2021.
Thread Status:
Not open for further replies.
  1. glenpinn
    glenpinn Member
    Dec 11, 2006
    6,654
    Hey peeps, i need to buy a couple of these Reciprocating Linear Actuator devices, it needs to be at least 95rpm or higher, and it must have a stroke of 150mm minimum.
    I can buy one to suite these requirements, but do i buy a 12v or 24v one for use here in Aust, i figure that the power adaptor/speed controller will have a US plug on it.
    https://www.ebay.com.au/itm/303912361394?hash=item46c2969db2:g:kqYAAOSwZ3Ffs55L
    Any Thoughts appreciated.
  2. paulvk
    paulvk Member
    Mar 10, 2010
    1,081
    Why does it have to be reciprocating , why not just a linear one
    glenpinn
    glenpinn Member
    Dec 11, 2006
    6,654
    Because
    I need it to operate like this one does (the same as the one that i linked to)
    The non reciprocating ones i found are cheaper, and they are slow as shit, and no way is going to do what i need it to do.
    https://www.ebay.com.au/itm/373103710531?_trkparms=aid=1110006&algo=HOMESPLICE.SIM&ao=1&asc=233149&meid=adf9d93b9aba42e297a89e87ff5410c6&pid=101195&rk=10&rkt=12&sd=313563389497&itm=373103710531&pmt=1&noa=0&pg=2047675&algv=SimplAMLv9PairwiseWithPLXWeb&_trksid=p2047675.c101195.m1851&amdata=cksum:373103710531adf9d93b9aba42e297a89e87ff5410c6|enc:AQAGAAACAEZGdu4cPnpSdHQSxrRASpe3LJs%2FHtELuWhipsk6ZOCtsTpFSmImWlhtniZo3aaJp3imboHLH5CUijZppAHDodJMbvlsHI%2BgxfA%2FCM0GMoHtEWHMJxnB0WnippkZ%2FpurVgb2qQG9FcDAKFEIGgowMH2YxU25%2FFuTcNU2C07EBOlcLw2N0rv4%2BvhWWr9EQVwjStApkY19FOuWiwoRxWt4N0mDGdO10nJ%2BMYcaP6WlrnTn5wH6yW8K81Zqj1%2BnI%2BKi7mmXRPeD7Ly9yTi8sbnvgAeRYFfBZf95igxnGzo%2BuDC1zuKw9K4MMOdJemgvDtB%2FWD9FatxIcRYhc25l8UoQQ%2BZ3a0m08Zw2hwnj9qIy6R2YswoNJgKunoMTsomjotH%2BFGTw%2FvQKNpcd4xIYVYFsztWh0dgwa3Rz1I6%2BBDG2%2B1h%2BylqgfYOZVhjLpopu4%2FBQSRs2P8pbk76a8UddNwTjgFczTzUNSKZ260e%2Bh3oFsfIhwipNL9hodYc1qN2lbEG8CqL7fH1Kz2haUHIKEgG0SmYb7phOrZMuIenJPNlGHU%2BSYUB725Qg2ncS2X5hBD67KkHUxRvhpfDaKhSUYD4XY8tqBcsNbIP4PQtfZSqzcI0Zr09hZ6NOCaoTl%2BWa2i5WxMo60JRIGW%2FUzLAtJ8C0conw7D3YecBfSSw7aiEgVFcM|ampid:pL_CLK|clp:2047675
  4. oculi
    oculi Member
    Aug 18, 2004
    11,864
    What's it for?
  5. Symon
    Symon Castigat ridendo mores
    Apr 17, 2002
    5,057
    Brisbane QLD
    Doesn't really matter if you get a 12V or 24V one, both will do the job. But since it has a US plug on the power supply it may only be able to handle a 110V supply.
    Not a major problem, 12V and 24V power supplies are pretty inexpensive if you need to replace it.
    From looking at the video I really don't want to know what you are going to do with it.
    glenpinn
    glenpinn Member
    Dec 11, 2006
    6,654
    Thank you Symon, nice reply.
    I emailed the seller 20 minutes ago about the plug, she just replied a few minutes ago with the following reply.
    "Thanks for your email. Yes, i will send the AU plug power supply. When you receive it you can use it directly"
    I also asked which voltage i need to order for Australia, she never answered that bit.
  7. Cererus
    Cererus Member
    Jan 14, 2002
    1,683
    Well... he needs something that goes one direction and back again at 95rpm, with a stroke that's 150mm/6" or more
    the only thing I can think of is that he's sifting a large amount of flour or dirt therfore he's either a baker or a keen gardener
    Symon and Pugs like this.
  8. Symon
    Apr 17, 2002
    5,057
    Brisbane QLD
    230-240V is the answer you are looking for.
    glenpinn
    glenpinn Member
    Dec 11, 2006
    6,654
    And this is exactly why i ask other people about electrical related questions, so i should be asking the seller this question, as i can't find any specs on this that will tell me.
    As far as the other comments being bandied around regarding the intended use for these items, well you know that i am not going to tell you because it is not relevant to the question being asked, and secondly, your guess would actually be 100% wrong anyway, we all know that these devices can actually be used for other purposes aside from making a thrusting sex machines :tongue::rolleyes:
    One day you just might see these devices in use on a project that i am working on, they may not even work in the way that i need them to, could be a total waste of time and money, but they should go close.:thumbup: and i am not buying the remote control or the frame.
  10. ArmoureD
    ArmoureD Member
    Sep 12, 2002
    829
    Earth
    Settle down.
  11. paulvk
    paulvk Member
    Mar 10, 2010
    1,081
    By not telling us the use or approximately the use we can not give meaningful advice , for one thing the devices you have shown will have very little strength and any reasonable force put on the unit will bend the shaft.
  12. holdennutta
    holdennutta Member
    Apr 14, 2002
    8,037
    Exactly what someone making a reciprocating sex machine would say.
    heller44, JaC, CacTuar and 7 others like this.
    glenpinn
    glenpinn Member
    Dec 11, 2006
    6,654
    Fuck me drunk, i don't have to explain the purpose of the device for you lot, i need 2 of those exact devices, and i already know their capabilities as far as the push/pull strength, and what weight it is capable of moving, so nobody needs to ask, and it's intended use has absolutely nothing to do with the question that i was asking, which was to do with the 12v/24v rating and which one i should get for use in Australia.
    So fucking simple, obviously not for some of you lot.
Thread Status:
