recomendations for active subwoofer
Discussion in 'Audio Visual' started by [RMS] ST1NG3R, Oct 4, 2013.
  1. [RMS] ST1NG3R
    [RMS] ST1NG3R Member
    Feb 8, 2010
    446
    3170
    hey guys, reasonably new to A/V stuff, but a few months back I picked up a Yamaha receiver off these forums which has been running absolutely awesome in a 6 channel set up in my room.
    Anyways I'm in the market for an active subwoofer to go along with it. I'm wanting something with a bit of boom as I listen to a bit of electronic music and will also watch movies with it.
    Budget is $300. Don't mind if new or used. Recommendations please! :D
  2. Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,506
    The Shire, Sydney
    [RMS] ST1NG3R
    Feb 8, 2010
    446
    3170
  4. damo2002
    damo2002 Member
    Jul 9, 2007
    226
    Melbourne, 3085
    Trevor Lee's Audio in Kew used to always have the Richter Krakatoa on their eBay page for about $350. They don't seem to have it listed anymore, but as of last time I was in there they still stocked them - might be worth calling to find out! I bought one, love it for the price.
    Very well looked upon subs, and if you're strict on budget you probably won't be able to do much better!
    [RMS] ST1NG3R
    Feb 8, 2010
    446
    3170
    Went down to a local cashies today,
    any thoughts on a welling ws10 or sherwood sp212w? $99 and $129 respectfully.
    otherwise im looking at a JENSEN QX-85 for ~$200.... though apparently these arent that good? :S
  6. steffan72
    steffan72 Member
    Aug 9, 2004
    1,065
    you really do get what you pay for.............stretch and get the paradigm. You will find the cheaper ones like you have mentioned are too loose and boomy........it will drown out everything else. I listen to psytrance and prog trance most of the day so i get what your listening to. you will only end up upgrading the cheaper sub as you wont be happy with it......so get the better sub to start with
    [RMS] ST1NG3R
    Feb 8, 2010
    446
    3170
    recommendations? :D anything, brand, models, price points!
    [RMS] ST1NG3R
    Feb 8, 2010
    446
    3170
  9. adslnewbie123
    adslnewbie123 Member
    Mar 12, 2006
    41
    melbourne
    You really do get what you pay for. They are generally as Steffan72 said loose and boomy and intact quite hollow sounding. Having said that if you're on a budget and plan to upgrade at a later date hey thheres no harm in going the second hand route. Pop over to DTV forums with you're requirement and Im certain you'll find what you need.
    In terms of brand theres just too many haha. Paradigm, Velodyn. B & W. Heck if you're into supporting Australian brands Ritcher and Krix offer some gems too. But hey if you can at least audition a sub prior to buying and you're happy with it. Too easy!
  10. MUTMAN
    MUTMAN Member
    9,125
    4109
    hunt around secondhand
    patience will get you something really nice
    i grabbed a paradigm sub on stero nets forums years ago. bargin too, it can move internal organs around :lol:
    [RMS] ST1NG3R
    Feb 8, 2010
    446
    3170
    names to look for then? :)
  12. Sledge
    Sledge Member
    Aug 22, 2002
    8,745
    Krix... Though brand new would be more than $300
  13. MUTMAN
    MUTMAN Member
    9,125
    4109
    :thumbup: ..
  14. steffan72
    steffan72 Member
    Aug 9, 2004
    1,065
    Paradigm, definitive technology, Krix
    [RMS] ST1NG3R
    Feb 8, 2010
    446
    3170
    cheers guys :D I'll keep looking :thumbup:
    [RMS] ST1NG3R
    Feb 8, 2010
    446
    3170
    Looking at a Jamo sw505e for $349... thoughts?
  17. MUTMAN
    MUTMAN Member
    9,125
    4109
    price is about right if its in good condition... have you listened to it yet ?
    [RMS] ST1NG3R
    Feb 8, 2010
    446
    3170
    At a cashies, so hopefully I can test there :)
  19. Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,506
    The Shire, Sydney
    you're almost in brand new Paradigm territory there, which will come with full warranty ;)
  20. [KEi]SoVeReIgN
    [KEi]SoVeReIgN Member
    Feb 20, 2002
    8,587
    Slightly off topic - I recently acquired the subwoofer out of the paradigm CT-110 5.1 system but haven't been able to find out much about it. How does it compare to the rest of Paradigm's range?
