Recommendations for freezer storage containers
Discussion in 'Geek Food' started by methodMAN, Sep 2, 2021.
  1. methodMAN
    methodMAN Member
    Jul 8, 2002
    2,619
    God's Own
    Looking for recommendations for freezer storage containers.
    Currently use the good ol "Chinese takeaway" container, but they don't make them like the use too any more.
    They are very thin and brittle.
    I was looking on ebay at meal prep containers as they are deemed "reuseable".
    I like the takeaway container style in either 500/750ml capacity as they stack and fit neat in my freezer - side by side so its narrow.
    I'm not a meal prepper as such, but cook in bulk as I work shift work.
  2. Quadbox
    Quadbox Member
    6,913
    I havent come up with a better solution than vacsealing everything (liquid stuff and meals I freeze in whatever container first and then vacseal). Hate the use of single-use plastic, but it takes up way less room, isnt fragile, and suffers way less from freezer burn. And vacseal rolls are cheap.
    Oh and reheating direct from frozen by throwing into a sous vide bath is convenient.
    caspian likes this.
  3. mareke
    mareke Member
    Jun 1, 2003
    8,453
    Sydney, NSW
  4. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    165,319
    Omicron Persei 8
    The Systema range is always pretty reasonable imo. Comes in plenty of sizes, and well priced when they do those half price specials. Just make sure you choose the "freezer safe" ones with the symbol on the bottom.
