recycling heat
Discussion in 'Electronics & Electrics' started by weak beta male, Dec 7, 2018.
  1. weak beta male
    weak beta male Member
    Aug 21, 2018
    56
    why isn't there a device to recycle the heat from computers to produce more electricity? i didnt major in physics but i know as long as there's a temperature differential then u can do work. with the amount of heat pcs and monitors produce u'd think they'd make a device to save electricity bills.
  2. Hive
    Hive Member
    Jul 8, 2010
    5,065
    ( ͡° ͜ʖ ͡°)
    Yes
    Pugs likes this.
  3. Hater
    Hater Member
    Nov 19, 2012
    3,092
    oh boy...
    Pugs likes this.
  4. Hive
    Hive Member
    Jul 8, 2010
    5,065
    ( ͡° ͜ʖ ͡°)
    Fine i'll bite.
    The things that power satellites in the absence of solar/battery - radioisotope thermoelectric generators. You could apply the fundamental technology (replace radioactive heat decay source with computer heat - maybe heat piping would work nicely)
    There, you're generating a few watts and it's cost you a shit load in materials. You will never get even remotely near 100% efficiency though, try more like 1-5%
    Pugs likes this.
  5. Supplanter
    Supplanter Member
    Jun 30, 2005
    478
    Wobbies World
    You could use the excess heat to power a Sterling Engine, and then use the output of that to drive a fan blade
    at 5RPM.
  6. SLATYE
    SLATYE SLATYE, not SLAYTE
    Nov 11, 2002
    26,823
    MSI actually did make a mainboard with a Stirling-cycle fan (which was then used to cool the chipset).
    The problem is that any thermodynamic machine works better when there's a big temperature difference between the hot side and the cold side ... and the devices generating the heat (eg. CPUs and GPUs) work best when they're pretty close to room temperature. Say you've got a CPU at 343K (70°C) (which is pretty hot!) and ambient temperature is 293K (20°C). The Carnot efficiency for this system is about 17% - so if you've got a 100W CPU then you can generate up to 17W from it. Realistically, you're going to lose energy at every stage, so 5W is probably a better bet for how much power actually goes back into the mains.
    Working against this is the fact that silicon devices actually use more power when they're hot (because heat lowers the resistance in a semiconductor). From the plots I can quickly find on Google, it looks like fitting a bigger heatsink to your 100W CPU to bring the temperature down from 70°C to 55°C will save you about 7W of power.
    RobRoySyd likes this.
  7. Sunder
    Sunder Member
    Apr 26, 2012
    3,004
    Wait what? You mean you haven't been installing a peltier between your CPU/GPU and the heatsink for the last 20+ years? The frigging things cost $1 each + shipping, to me, that's like leaving the light on because you couldn't be bothered getting up to turn it off - You're just wasting money and killing the planet.
    https://www.ebay.com.au/itm/New-TEC...h=item28705ebae8:g:rIkAAOSwe9FcC5u7:rk:1:pf:0
    You're welcome.
    (Disclaimer, there's a missing sarcasm tag there... While this would work in theory, just like putting a hydro-electric generator in a stream would slow down the flow of water, putting a peltier in a "stream" of heat, slows down the transfer of heat, so your "hot" side would probably keep thermally throttling your CPU/GPU).
