Replacement battery- iPhone 4S
Discussion in 'Apple iOS (OS & Devices)' started by mcfee03, Aug 8, 2014.
  1. mcfee03
    mcfee03 Member
    Jan 28, 2007
    835
    My iPhone 4S has had it.
    At 11pm last night, the battery was on 86%.
    The alarm on the phone went off at 6:30am this morning and went flat about 5 seconds into the alarm to
    Is it definitely the battery or could something else have caused this?
    Is there a battery monitoring app?
    I've got an old iPhone 4, but the battery is slightly lower power at 1420mha (4s is 1432mha). Should that matter?
    Can any of the cheap eBay one's be trusted? Or are they likely to be much lower-power than advertised?
  2. power
    67,116
    EBay 2 screws cover another screw replace ip4 batteries are a no brainer really. Also did I read right you didn't charge overnight?
    mcfee03
    mcfee03 Member
    Jan 28, 2007
    835
    No I didn't- normally I do but it went flat at about 6pm so I thought I didn't need to
    I've got the tools-are you saying the iPhone 4 battery won't work because of screws?
  4. power
    67,116
    no I'm saying that replacing a battery in the 4 is a quick easy job.
    Being a 4S it's what 2-3 years old?
    Are you charging with at least a 5W charger not an old iPod one?
  5. FoBZY
    FoBZY Member
    Jun 3, 2002
    3,127
    I got a genuine off ebay for like $30 , came with the tools too. Was $10 more than a non genuine, took like 5 mins to change
    mcfee03
    mcfee03 Member
    Jan 28, 2007
    835
    Ok cool. Think it's 3 years old, but was probably left idle/un-used for about 4 months. Yes I'm using the new charger and cord.
    However, I'm using my iPad air charger (it's a 2amp or fast charger). Original apple. Could this damage my battery?
    Before I replace the battery, I might try removing the jailbreak. What's the best way to un-jailbreak- just a backup then restore via iTunes?
  7. power
    67,116
    Air charger is probably 10 or 12 watt, will do no damage.
  8. booksacool1
    booksacool1 Member
    Feb 24, 2005
    1,224
    The iPhone and iPad charger use a proprietary method to communicate. The iPhone will modulate the charging rate as necessary.
    mcfee03
    mcfee03 Member
    Jan 28, 2007
    835
    Well I stopped using the iPad air charger (2.0a) and it seems like the problem has gone away.
