Replacement bbq hotplate
Discussion in 'Geek Food' started by blued, Jan 27, 2019.
  1. blued
    blued Member
    Apr 29, 2008
    259
    Hello. I have a bbq which is half grill and half hotplate. Looking to get a second hotplate and get rid of the grill part but cant find a hot plate that'll fit.
    The current size of the grill is 460mm x 220 mm. Same as the hotplate. A maximum of 470 mm by 450 mm hole exists.
    The only plate I can find would result in a loss of 5 cm. That's alot of realestate on a small bbq.
    Surely I don't need to to just buy a new bbq...
    Has anyone got a custom stainless steel plate cut and bent to a custom shape?
  2. kooksyau
    kooksyau Member
    Oct 17, 2006
    349
    It would probably be cheaper to buy a new flat plate bbq than get a custom stainless plate cut and folded. Or just gumtree it.
  3. firey4059
    firey4059 Member
    Jul 24, 2007
    70
    Greensborough
    Gidday blued.
    I recently had cause to replace some consumable items from my bbq. I was surprised at the prices charged by the specialty bbq stores. I went to Bunnings and they had a reasonable range of products at very reasonable prices. In regards to plates, grills, flame tamers, if you have access to a angle grinder, you can cut down any of these items quite easily to fit your bbq thereby maximising your bbq real estate.
    Cam.
    blued
    blued Member
    Apr 29, 2008
    259
    I'm thinking that but seems so wasteful.
    Thanks. I did check out the range at Bunnings. I'll give them another look.
    firey4059 likes this.
