Replacement graphics card
Discussion in 'Video Cards & Monitors' started by IgglePiggle, Jun 28, 2019.
  1. IgglePiggle
    IgglePiggle Member
    Mar 6, 2012
    66
    In The Night Garden
    My now old PC has been thumping along for about 8 years now without a problem ... but Ive gone from triple monitors to 2 , then 1 , but now its had enough on the last display also
    Im just going to replace the card ... would the one linked below be compatible with what I have .... I even found a list of specs when I built it but havnt kept up with the latest gear for years
    I multitask moreso than gaming but multiple monitors are a necessity
    Thanx
    https://www.pccasegear.com/products/41761/asus-radeon-rx-580-dual-gaming-oc-8gb
    CPU : AMD Phenom II X4 955 Black Edition 3.2GHz
    HSF : Xigmatek HDT-S1283 Red Scorpion
    MB : Gigabyte GA-790XTA-UD4
    RAM : G.Skill Ripjaws F3-10666CL7D-4GBRH (4x2GB) DDR3
    GPU : Gigabyte ATI Radeon HD5770 1GB
    PSU : Seasonic X-Series 750W
    Case : HAF 932
    Monitors : 3 x BenQ G2420HD 24in LCD
    OS : Win7 Ultimate 64bit
    darkanjel and nope like this.
  2. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    IgglePiggle likes this.
  3. 2_stroke
    2_stroke Member
    Aug 9, 2008
    1,287
    cranbourne 3977
    Yer will be fine, you could save some money with a rx 570 or even rx 560 though if you’re not gaming or using opencl.
  4. d_prac
    d_prac Member
    Apr 12, 2015
    100
    Looks fine to me. What's the problem?
  5. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
    They are not on acid and coming down...........
    2_stroke likes this.
  6. nope
    nope Member
    May 8, 2012
    2,882
    nsw meth coast
    rx570 used off these forums
    IgglePiggle
    IgglePiggle Member
    Mar 6, 2012
    66
    In The Night Garden
  8. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
    Careful as they are from the same user (with a low rep count) and would be ex-mining units.
    GTX1060 6G GDDR5 192Bit PCI-E Game Video Card Graphics Discrete Game Graphics - AU $107.53 - but has to come from Hong Kong if you can wait?
    https://www.ebay.com.au/itm/GTX1060...341323?hash=item3409b7d28b:g:nYoAAOSw2kJcyDuS
    It beats the RX570
    https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1060-6GB-vs-AMD-RX-570/3639vs3924
    Gigabyte Aorus RX570 4GB Videocard - $135 with a Postage: AU $14.55 Standard Postage
    https://www.ebay.com.au/itm/Gigabyt...162929&hash=item592dd99176:g:5oYAAOSwIKZc~3sa
    IgglePiggle
    IgglePiggle Member
    Mar 6, 2012
    66
    In The Night Garden
    Ive discovered 2 of my monitors have died also .... whats the best connection? ... DVI, HDMI or display port? .... looking at monitors and , like the graphics cards , a lot dont have them all
    So many monitors on the market these days! ..... budget is around $300 ..... anything worthwhile here (JB HiFi) ?
    Or this for split screen multitasking ....
    https://www.harveynorman.com.au/lg-31-5-mp58-full-hd-ips-monitor.html
    or this ...
  10. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
    What makes you think the monitors are gone? Could it be a symptom of the failing/failed GPU?
    JB HiFi will cost a lot more than Umart, MSY or Computer Alliance.
    What is your postcode?
    DATA transfer rates (and thus better quality) are highest with DP>HDMI>DVI. So DP is the best quality but be aware they have newer forms.
    https://www.gamingscan.com/hdmi-vs-displayport-vs-dvi-vs-vga/
    https://www.expertreviews.co.uk/acc...port-vs-dvi-vs-vga-every-connection-explained
    That is there is;
    - DP is upto 1.4, from 1.2 to 1.3 and now 1.4,
    - HDMI is upto 2.0, from 1.4,
    - DVI can be 'dual'
    https://www.quora.com/Currently-what-is-more-modern-better-HDMI-or-DisplayPort
    You need to determine what is the max GPU output potential and then find a suitable monitor.
    IgglePiggle
    IgglePiggle Member
    Mar 6, 2012
    66
    In The Night Garden
    I just plugged them into power and turned them on .... on 2 of them the splash screen dies instantly (and is very dull) and the 'no cable detected' box is the same .... goes off straight away
    My postcode is 2340 ... regional .... I just used JB as a bit of a guide and anything I find suitable to buy I would hunt down a best price
    more research needed! :)
    cheers
  12. cbjaust
    cbjaust Member
    Sep 11, 2003
    1,279
    You should make sure any monitor you get has display port at minimum. Any extra inputs after that are a bonus.
  13. asho444
    asho444 Member
    Feb 7, 2012
    1,507
    Sunny Coast
  14. nope
    nope Member
    May 8, 2012
    2,882
    nsw meth coast
  15. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
    I would never buy a Kogan TV (sooooo many bad reviews) but there monitors are ok?
    https://www.ozbargain.com.au/tag/lcd-monitor
    While I was looking at OzBargain I came across this deal (which ends today);
    https://www.ozbargain.com.au/node/466932
    33% Off BIOSTAR GPUs - RX 580 8GB 2040SP (Stock OTW), was $300, now $201
    https://www.cgbsolutions.com.au/specials
    I have been trying to research the company to make sure they are not a bunch of crooks as that is an incredible price but are having troubles finding any meaningful info on them?!?
    CGB Solutions
    IgglePiggle
    IgglePiggle Member
    Mar 6, 2012
    66
    In The Night Garden
  17. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
    The monitor will come with a DP cable. Yes that is a crazy price when I can find them for less than 1/2 that;
    https://www.ebay.com.au/itm/4CABLIN...493064?hash=item41ffeb6c88:g:DOYAAOSwfHBcxiEQ
    Not sure about that monitor but there are reviews for it.
    IgglePiggle
    IgglePiggle Member
    Mar 6, 2012
    66
    In The Night Garden
    Im going to take a punt on the Kogan curved monitor
    Whats happens with a card thats used for 'mining' .... does it run full tilt 24/7?
    A new 570 is $179 at Umart ... so that could be the better option
    thanx everyone for your input
  19. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
    Mining cards are on 24/7 so they can have a hard life. Experienced users modify the BIOS to 'undervolt' them to reduce the wear potential - when they sell them they reflash back the original BIOS.
    You didn't think the RX580 a bit interesting? I think the sale is over now.
    IgglePiggle
    IgglePiggle Member
    Mar 6, 2012
    66
    In The Night Garden
    Missed that one .... it says its ending last night but it still comes up in the cart at $201 .... I guess technically speaking end of financial year is midnight tonite
