required sample cut cnc router/engraving copper
Discussion in 'Hobby Engineering' started by vltrb-0, Apr 6, 2015.
  1. vltrb-0
    vltrb-0 Member
    May 11, 2006
    622
    melbourne
    im looking to purchase a cnc router for cutting copper something along the lines of a 3040 with a budget of approx AU$1500 (can spend more if required)
    Prior to making a commitment i'd like to test this out on a machine of this budget if someone has one available.
    Main concerns are how the machine copes cutting copper, accuracy, duration and reliability
    Material will be Copper Alloy 110 1/2 Hard, 2mm thick and a shape roughly 100mm x 100mm, mill would be required to cut through entire 2mm sheet to release the component
    I have CAD drawings available but have only previously had them cut using fibre so the file may need to be altered to allow for mill bit
    Happy to exchange material, supply suitable cutting bits or compensation for time etc
    Located Melbourne Metro
    Thanks
  2. pippin88
    pippin88 Member
    Jul 26, 2001
    7,406
    Newcastle
    You should look at a mill rather than a router. I think copper benefits from flood coolant also.
    What was wrong with getting them cut with fibre?
    vltrb-0
    vltrb-0 Member
    May 11, 2006
    622
    melbourne
    flood coolant is prefered but hoping i can get away without it on small jobs
    fibre cut process is amazing, excellent finish but i have no control over turn around time (upto 3 weeks), large min orders, poor tolerance control and i'm finding i don't get all of the scrap material back :rolleyes:
  4. ericks
    ericks Member
    Nov 3, 2012
    87
    I have a 6040 and use it on plastic, alum, copper and brass up to 10mm thick. There will be some flex on the machine with these metals if you try to cut too much per run. I take off a small amounts but at high feed rate. My machine is very accurate, I also use it to machine pcb's. If I had to do it again I would buy the 3040 with no electronics. On my machine I replaced the spindle motor and the stepper drivers. Haven't ever "missed" a single step since...:)
  5. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,612
    Nulkaba
    Hey Op, National manufacturing week is in melb next month, if you get a chance go check it out & speak to the different seller;)
