Restore iBook/iBook G4 without OS X disc
Discussion in 'Apple Desktop Hardware/Software' started by Stooge007, Jan 1, 2020.
  1. Stooge007
    Stooge007 Member
    Aug 22, 2006
    10,623
    The Shire, Sydney
    hi all
    cleaning out the garage, and i've got 3 x iBook G4's and a previous gen iBook i want to tidy up and donate/sell to a collector
    so from what i read on Google, i need the Mac OS X disc to do a full factory restore
    i don't have these discs
    so i did some more searching, and did this to one of the machines (one of the G4's):
    1. boot computer and hold the "apple" key and the "s" key.
    2. wait for terminal show
    3. release keys
    4. type without the quotes: "/sbin/mount -uaw"
    5. press enter
    6. type without the quotes: "rm /var/db/.applesetupdone
    7. press enter
    8. type without the quotes: "reboot"
    9. press enter
    this then took me through the set up process that seemed to me you would go through when purchasing a new computer (i.e. add user, select time/date etc.)
    but i do not think the above necessarily properly wipes the HDD?
    only 1 of these machines has some semi-sensitive info on it (the older iBook), the others probably not so much
    what's the best way to factory reset these things without a Mac OS X disc?
    or should i just pull the HDD from the older iBook and just run the above on the iBook G4's?
    or pull all 4 x HDD's and burn them in a fire?
    i am not an Apple person, as you might tell!
    any help appreciated
    cheers
  2. bYrd
    bYrd Member
    Sep 14, 2001
    2,015
    NE Melbourne
    As expected the commands you've tried do not wipe a single file - and it's a pain to get to the HD in an iBook taking many steps of disassembly.
    Here are the OS X CD image files you need to format the HD and start afresh - go Panther/Mac OS X 10.3.x for any iBook < 256MB RAM and Tiger/Mac OS X 10.4.x for >256MB. Ideally just burn the images to CD, there are methods to boot from USB but it's not officially supported and can result in pulling at hairs.
    https://macintoshgarden.org/apps/mac-osx-mac-os-10-ppc
    Put in CD at startup, and hold down "C" immediately after the chime to boot from it. Don't forget to run Disk Utility when booted to hose the HD and reformat.
    JB
  3. mr camouflage
    mr camouflage Member
    May 25, 2012
    922
    Reinstalling the OS isn't technically going to wipe the hard drives either. Files may remain on the drive that can be recovered via un-eraser type programs.
    To securely erase the drive (note this will erase the drive and OS completely)
    from https://www.backblaze.com/blog/how-to-wipe-a-mac-hard-drive/
    How to Wipe a Mac Hard Disk Drive (HDD)
    1. Make sure your Mac is turned off.
    2. Press the power button.
    3. Immediately hold down the command and R keys.
    4. Wait until the Apple logo appears.
    5. Select “Disk Utility” from the OS X Utilities list. Click Continue.
    6. Select the disk you’d like to erase by clicking on it in the sidebar.
    7. Click the Erase button.
    8. Click the Security Options button.
    9. The Security Options window includes a slider that enables you to determine how thoroughly you want to erase your hard drive.
    There are four notches to that Security Options slider. “Fastest” is quick but insecure — data could potentially be rebuilt using a file recovery app. Moving that slider to the right introduces progressively more secure erasing. Disk Utility’s most secure level erases the information used to access the files on your disk, then writes zeroes across the disk surface seven times to help remove any trace of what was there. This setting conforms to the DoD 5220.22-M specification.
    *Note: Selecting the second level is usually enough. level 4 is a waste of time.
    1. Once you’ve selected the level of secure erasing you’re comfortable with, click the OK button.
    2. Click the Erase button to begin. Bear in mind that the more secure method you select, the longer it will take. The most secure methods can add hours to the process.
    Once it’s done, the Mac’s hard drive will be clean as a whistle and ready for its next adventure: a fresh installation of OS X, being donated to a relative or a local charity, or just sent to an e-waste facility.
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    10,623
    The Shire, Sydney
    thanks guys, will give it a crack :)
    cheers
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    10,623
    The Shire, Sydney
    do i need to convert the toast file to a dmg?
    i originally downloaded 10.3 but just checked and the iBooks are running 10.4
    SMH
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    10,623
    The Shire, Sydney
    can't get Command + R to boot into recovery mode :(
  7. sammy_b0i
    Jun 29, 2005
    3,723
    ACT 2913
    You can do those same steps, but not from Command+R, do it once you boot to the image you've downloaded. Can still access disk utility from the menu at the installer screen.
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    10,623
    The Shire, Sydney
    currently downloading Tiger images ...
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    10,623
    The Shire, Sydney
    so i found some OS X discs
    none of the computers will boot to CD (hold down C), and won't boot to recovery to wipe them (hold down Command + R)
    so frustrating!
    do you need to wait for the start up chime before pressing the buttons?
    i tried the buttons before and after the chime, still didn't want to boot to CD or recovery
  10. sammy_b0i
    Jun 29, 2005
    3,723
    ACT 2913
    Try holding the option key instead of C
    Stooge007 likes this.
  11. damo13579
    damo13579 Member
    Oct 21, 2008
    1,203
    Tas
    Command + R isn't going to work on that mac, it only works on macs running 10.7 or later to boot to the recovery partition, 10.6 and earlier don't have a recovery partition.
    Holding C should get it to boot from the DVD drive.
    Holding option will get you to the screen where you can pick from any available startup discs. Try this with the disc in the drive, if it doesn't appear either the disc has an issue or the drive has an issue.
    the OSX discs you've found and tried, which OSX version are they? Note that if they are the grey discs with white writing on them they are model specific and wont work if you have the wrong ones, the Retail discs have a big X on them and should work without too much issue.
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    10,623
    The Shire, Sydney
    yeah, they're grey discs with white writing
    do i need to convert a toast file to dmg or iso for it to boot from CD?
  13. sammy_b0i
    Jun 29, 2005
    3,723
    ACT 2913
    Not if you use the Toast app to burn it, I assume (but could be wrong)
    damo13579 likes this.
