Retro display solutions (monitors, TVs, CRTs, flatscreens, upscaling, calibration)
Discussion in 'Retro & Arcade' started by elvis, Jul 24, 2018.
  1. WuZMoT
    WuZMoT Member
    Feb 2, 2002
    2,412
    $3.62 of M3 bolts from bunnings.
    some acrylic scrap scored to size with a stanley knife.
    dremel cut the bolts, dremel sand the acrylic corners.
    clear vinyl tubing from an old molex cable sleeve.
    leftover black plastic screw caps for legs.
    If only soldering was this easy.
    power, darknebula, Pierre32 and 3 others like this.
  2. WuZMoT
    WuZMoT Member
    Feb 2, 2002
    2,412
    elvis, Pierre32 and darknebula like this.
  3. darknebula
    darknebula Member
    May 21, 2009
    1,239
    Frankston
    Looks amazing
    Pierre32 likes this.
  4. Pierre32
    Pierre32 Member
    Oct 13, 2019
    671
  5. power
    64,604
    elvis
    elvis Old school old fool
    42,536
    Is the PS3 grunty enough to support run-ahead emulation?
  7. WuZMoT
    WuZMoT Member
    Feb 2, 2002
    2,412
    Maybe for some lower spec platforms but generally I don't think so.
    Super Mario World didn't feel 100% right but it was close.
    I'm going to dump some PS1 games onto it and do a side by side with the real PS1 running on svideo and see how close the ps3 emulation and downscaling can get to the real thing.
    elvis likes this.
    elvis
    42,536
    I'd love to see a 3-way combo between a real PS1, RetroArch PS1 and Sony's native PS1 emulator.
    elvis
    42,536
    RetroTink-2X Pro Multiformat beta firmware update out:
    Version 1.2 BETA
    *Pseudo-444 sampling mode for 480p inputs only. Set the 'Mode' switch to 'Line2x' to activate. Setting the 'Mode' switch to 'Pass' operates as before. Pseduo-444 is experimental only!
    *Improved sync detection.
    https://twitter.com/retrotink2/status/1305690318939910144
    https://twitter.com/retrotink2/status/1305712706318528513
    https://www.retrotink.com/post/retrotink-2x-pro-multiformat-firmware-page
  10. WuZMoT
    WuZMoT Member
    Feb 2, 2002
    2,412
    I don't think any PS1 cores were ported to the PS3 version of retroarch (not even PCSX)
    Happy for your thoughts on a platform/core assuming I can rig it up. Mednafen (standalone or Retroarch) on x86 via VGA @ 480p through the GBS would be a good comparison. I'll even upgrade the PS3 to decent quality cables just to make all results as good as possible. My high quality cables are generally reserved for permanent setups, I just have chinese cables floating around for testing/fiddling.
    So glad I picked up a Concord DSUB > Component cable from Jaycar for cheap when they were on clearance. It's the perfect partner to the GBS.
    elvis likes this.
  11. nic55
    nic55 Member
    Dec 29, 2005
    142
    Does anyone know the sync signal required to get VGA hooked up to an RGB monitor? (1084s).
    I've made a VGA to 6 pin DIN cable for use with AdvancedMAME and getting a clear image with vertical scrolling issues, I've used the VGA v-sync and h-sync signals separately with different results, perhaps need to combine sync from the both?
    Cheers.
    elvis
    42,536
    It's tricky, and highly dependent on the type of sync you're getting.
    Here's one you can build (assuming you meet the input requirements):
    https://www.retrorgb.com/building-a-passive-sync-combiner.html
    And if you're going out to an arcade monitor only, here's one you can buy (DO NOT use this on a consumer TV / PVM):
    http://www.ozstick.com.au/product/video-amplifier/
  13. nic55
    nic55 Member
    Dec 29, 2005
    142
