REVIEW Review: Audioengine A5 vs. Aktimate Mini
Discussion in 'PC Audio' started by spAm^bOy, Jul 6, 2012.
  1. hogpig
    hogpig Member
    May 30, 2010
    9
    Sydney, NSW
    Hey guys,
    I recently purchased a aktimate mini+ speakers and they sound great! But i encountered a problem where there is a excess amount of static/hiss noise when i turn the speakers on. I dont think i noticed it when i first test it but it became more obvious but the sound quality its still good.
    i asked the seller and he said its probably the amplifier noise and its normal but im not so sure. :confused: can someone tell me if this happens to their speakers ? cheers
  2. prax
    prax Member
    Jun 7, 2013
    2
    I have a aktimate micro, its already loud with its own dac but when hooked to xonar dx, its too loud! i have to have the digital volume to around 50% or lower. but generally just rotating the knob to 0 with that still gives me audible music. Is there something wrong here? unless i have xonar below 50% i cant go beyond 15% with the front knob.
  3. cdtoaster
    cdtoaster Member
    Jan 21, 2007
    4,787
    Tokara forest
    That sucks, I hope it's isolated and not indicative of the quality overall. Since my hi-fi order fell through I bought a set of A5+ with S8 for the interim. I'm really happy with the sound but it's too directional.
  4. Everlong
    Everlong Member
    Jul 12, 2011
    773
    Hysperia
    Audioengine (via PC case gear) sorted out the warranty nice and quickly and replaced with the newer A5+ model and so far no problems. I only use mine for nearfield listening so the directional sound isn't something I have noticed.
  5. Renza
    Renza Member
    Dec 1, 2004
    4,874
    I just bought some faulty Aktimate Minis off here for $100. fixed it up and its working brilliantly. I think the Atkimates are much better for nearfield listening. the A5 bass isnt good until you're at least 3m from them, so i don't think they're as suited for PC speakers.
    Haven't directly compared them, but I'll be keeping both anyway and can do a comparison soon!
  6. prax
    prax Member
    Jun 7, 2013
    2
    can anyone comment on the apparent volume oddities coming from aktimate micro? like how having its volume at 0 but with sound card at 100, you could still clearly hear the music. and how when turning the knob from zero it switches to the right speaker then balances as you raise the volume?
  7. garetz
    garetz Member
    Aug 7, 2002
    941
    2217
    Well finally got some aktimate mini+ for $445, i paired it with my audio-gd nfb-15.32, and coming from a logitech z680 i am impressed with the clarity and accuracy.
    I am however wondering if i should upgrade the speaker cable and or the interconnects ( as the interconnects are some cheap $1 job rca cables)
    Anyone upgraded anything on the speakers and saw a difference ?
    As far as i can tell you can upgrade the speaker cables, interconnects and power cable.
  8. KSB1978
    KSB1978 Member
    Jul 20, 2012
    17
    I personally do find cables to make some difference in a good system.
    Usually, the interconnects have a lot more profound effect, as the signal is then amplified after the change to the signal occurs.
    I suppose there is two camps of thoughts in this cable thing... people who believe it and people who don't. But if you break it down more, there are more camps. People who tried many cables and still haven't heard any difference, people who tried many cables and hears differences, people who haven't experimented but firmly believes it doesn't make any difference, people who haven't heard differences personally but understands things like this can make a difference, people who are deaf... people who chooses to deny he's been punched in the face because he hadn't done a double blind test about it... etc.
    In reality, cables have different electro-conductive characters and it makes differences to the electrical waves traveling through it. That surely makes a difference to the sound created.
    The point is not to spend more money... but look at the build quality of the connection, termination... how strong the RCA grips to terminal, stuff like that.
  9. garetz
    garetz Member
    Aug 7, 2002
    941
    2217
    I ended up upgrading the interconnects to Wireworld Solstice 6, which has some improvements, but not as much as i would expect.
    Where i noticed the big difference in change was when i upgraded the usb cable for the dac to a wireworld starlight 7, dam that really blew me away the difference it made.
    I might also try the chord crimson+ interconnects, see how i go.
  10. czman863
    czman863 Member
    Apr 20, 2009
    59
    Kingsford 2032
    garetz where did you get the Aktimate mini+ for $445?
  11. garetz
    garetz Member
    Aug 7, 2002
    941
    2217
  12. czman863
    czman863 Member
    Apr 20, 2009
    59
    Kingsford 2032
    I read on other forums some Aktimate Mini has hissing/white noise. Any of you guys experiencing that?
  13. Suopermanni
    Suopermanni Member
    Nov 3, 2010
    415
    Brisbane, Australia
    Maybe they are defective units or perhaps the cables connecting the speakers to the TV are not properly shielded? I have a pair and I haven't heard it since I got a decently shielded cable attached to the DAC, attached to the TV.
  14. garetz
    garetz Member
    Aug 7, 2002
    941
    2217
    I use the default cabling with the Aktimate Mini+ and get absolutely no hissing or white noise. However the interconnects it comes with is pitiful $1-2 cables.
    Its more likely the problem comes from the source than the speakers themselves. As long as you dont have substandard dac you wont have a problem.
    I have tested using a asus stx internal soundcard, and a audio-gd nfb15.32 TCXO external dac. I do notice some small barely audible hiss using the stx, but there is no noise when using the 15.32.
  15. czman863
    czman863 Member
    Apr 20, 2009
    59
    Kingsford 2032
    I just bought some Aktimate Mini+. They sound pretty good still, waiting for my DAC/AMP to come.
    But the ones i got seem to have the hissing noise. Can only be heard 5cm away from tweeters, when the speakers are turned on. This is without plugging any source in, it only has the power cable in the speakers.
    Could you double check again if you speakers have static noise from the tweeters when your ears are right up against the tweeters.
  16. garetz
    garetz Member
    Aug 7, 2002
    941
    2217
    I can hear a faint buzzing, with my ears 5cm away from the tweeter, happens even when muted. First time i noticed it, but its inaudible further than 5cm.
  17. czman863
    czman863 Member
    Apr 20, 2009
    59
    Kingsford 2032
    Yes that was the hissing I was talking about. I guess all tweeters have them. Ty for confirming, just making sure it wasnt just my speakers.
  18. SpicEwEazle
    SpicEwEazle Member
    Jul 1, 2005
    4,049
    Just jumped on these, driven from Xonar STX via RCA. Cost me over $800 to move to new speakers and the STX ( new wireless card, rca cables), but fuck, they sound amazing!
  19. TheImp
    TheImp Member
    1,664
    Indooroopilly
    Just pulled the trigger on a set. I'm looking forward to getting them!
  20. AgenaFX
    AgenaFX Member
    Jun 23, 2008
    352
    Manchester, United Kingdom
    Does anyone get feedback/noise from piano music/female vocal?
    I've been doing comparisons with my new Mini+ and my JBL LSR 2325P studio monitors and there always seems to be a slight buzz on high notes/frequencies.
    Once heard, I cannot unhear it. Very frustrating. Anyone else had this issue ?(related to tweeter buzzing?)
