RGB LED fans
Discussion in 'Modding' started by Will S, Sep 5, 2017.
  1. Will S
    Will S Member
    Aug 15, 2003
    4,061
    Coniston (Wollongong)
    Will have anm/bhttps://www.gigabyte.com/Motherboard/X299-AORUS-Gaming-7-rev-10#kf along with an Aorus 1080ti GPU and want to make the fans RGB the same as the Aorus stuff.
    Have a Corsair Graphite 780T White ATX Case and pretty sure I can remove the stuff at the top front and put in extra 140mm fan ( currently have 2 white only leds fans )
    Also have one 140mm exhaust fan at the back...............
    So what RGB 140mm fans are good ? Or more exact are there things to avoid ie. total shit
    Some how will in the end like to tie the colours in with the Aorus m/b and GPU so maybe some sort of controller may be handy.
    But I guess back on track...after quality RGB led fans ...any recommendations
    Will S
    Will S Member
    Aug 15, 2003
    4,061
    Have the HD 140mm fans and LED controller.............going to need to tidy up my cables
    Now the Corsair Commander Pro will tie in nicely ( have H115i cooler) and will then use link software to change everything
    Or is the Commander pro JUNK ?
  3. Tazor
    Tazor Member
    May 23, 2010
    1,528
    Canterbury, 3126
    Was gonna say, Phanteks Halos would be good, cos you can choose the fans and have syncable RGB.
