RJ45 socket wall plates
Discussion in 'Networking, Telephony & Internet' started by Sankari, Apr 8, 2010.
  1. Sankari
    Sankari Member
    Jun 13, 2009
    28,993
    Adelaide, SA
    I'm extending my network from one end of the house to another, and want to install a socket on the wall at each end. Ideally I would like something which allows me to plug an ethernet cable into the back of the plate and another one into the front. Does such a thing exist? If so, are they OK or is the connection a bit dodgy?
    Otherwise, what's my alternative and how do I wire it up? Are different faceplate sockets optimised for specific cables (ie. Cat5e) or will they work perfectly with anything?
    :confused:
  2. Pugs
    Pugs Member
    Jan 20, 2008
    9,242
    Redwood Park, SA
    if you can be bothered getting up into the dusty/smelly roof. there are products on the market..otherwise drop me a line and i can do all the dirty work for you...
    cablers won't use the "clip through" sockets as they tend to fail badly, also the "stranded" cable that patch leads are made of isn't suitable for in roof installtion
  3. Doc-of-FC
    Doc-of-FC Member
    Aug 30, 2001
    3,358
    Sankari
    Sankari Member
    Jun 13, 2009
    28,993
    Adelaide, SA
    Thanks pugs. I' spent two hours installing several dozen metres of Cat5e in the roof yesterday . It currently drops down from the ceiling at either end and I just wanted to tidy it up a bit. If the clip through sockets are no good, I'll avoid them.
    When you refer to stranded cable, do you mean the standard 8-core Cat5e/Cat6 cable? Why isn't it suitable for roof installation? What else would you use?
    :confused:
  5. Pugs
    Pugs Member
    Jan 20, 2008
    9,242
    Redwood Park, SA
    Solid core can only be used for installations. not my rules i just have to deal with them...
  6. Doc-of-FC
    Doc-of-FC Member
    Aug 30, 2001
    3,358
    Sankari
    Sankari Member
    Jun 13, 2009
    28,993
    Adelaide, SA
    I don't understand what you mean by "solid core." What is "solid core" cable? What does it look like, where would I get it, and is it illegal to run Cat5e or Cat6 through the roof?
    That's helpful but it seems to show regular Cat5e cable. What's this "solid core" business?
  8. Pugs
    Pugs Member
    Jan 20, 2008
    9,242
    Redwood Park, SA
    for you to do yes it is Illegal
    the stranded cable has very small strands of wire in them that make up the entire length makes them more flexible for patch leads and short runs where as in roof you need to have less flexibilty while "solid core" is a solid peice of copper wire inside the PVC jacket (still 4 pairs of wires in there)
    Sankari
    Sankari Member
    Jun 13, 2009
    28,993
    Adelaide, SA
    Well, too late. It's done. If the South Australian police want to come and arrest me, I'm sure they'll get around to it in their own time.
    How the hell can you attach a single solid core to an ethernet plug? Or do you only attach it to the wallplate? :confused:
  10. Pugs
    Pugs Member
    Jan 20, 2008
    9,242
    Redwood Park, SA
    it still has 8 inner wires..... they get punched down...
    Sankari
    Sankari Member
    Jun 13, 2009
    28,993
    Adelaide, SA
    Can you post a pic, please? Is Cat6 a solid core cable?
  12. cvidler
    cvidler Member
    12,768
    Each of those 8 wires, has a solid copper core, instead of each of the 8 wires being made up of multiple fine strands of copper.
    No, you can get solid or stranded in all categories of cable.
    Solid core is used for fixed installations, it conducts better, but is less flexible, and prone to internal breaks if it's flexed to much. Stranded is used for patch leads because it is nice and flexible and won't break as easily, but is a poorer conductor, so only used in short lengths where possible.
    Sankari
    Sankari Member
    Jun 13, 2009
    28,993
    Adelaide, SA
    Good grief, these terms are all so ridiculously misleading.
    If someone said "solid core" to me, I would take this to mean a single strand of solid wire. I would not take it to mean eight separate strands of wire with a piece of plastic in the middl.
  14. ewok85
    ewok85 Member
    Jul 4, 2002
    8,074
    Tokyo, Japan
    This isn't consumer products - this is stuff used by people who have training and licenses in how to use them :rolleyes:
    It isn't misleading at all, you just lack to knowledge to make the connection.
    Sankari
    Sankari Member
    Jun 13, 2009
    28,993
    Adelaide, SA
    They are consumer products. I walked into Dick Smith and bought 5m of Cat6 yesterday. Very simple. Nobody stopped me at the door and said "That's not for consumers, give it back!" :wired:
    Yes, I lack the knowledge to "make the connection" (nice pun!) That's why I'm here, asking questions. :)
  16. infiltraitor
    infiltraitor Member
    Sep 7, 2002
    3,801
    melbourne Donated:$133.70
    all consumer network cables that you buy from dick smiths are stranded core and not suitable for in-wall installations
    the "non-consumer" stuff you'd get in a big reel from middys etc. you'd get about 300m of it. have to punch down into a wall port etc (or add your own RJ45 ends if you're that way inclined.
    the cops wont come after you about uncertified cabling but if your insurance company finds out they will void your insurance and if it causes any issues (like shorting out power) you arent covered
  17. Pugs
    Pugs Member
    Jan 20, 2008
    9,242
    Redwood Park, SA
    that would be because they are "patch leads" used on the customer side of the wall plate not the other side.. DS, JC and other "electronics" stores don't care if you are a licenced cabler or not they are just selling a product. 99% of ther staff are purely sales people
  18. Vladdo
    Vladdo Member
    Apr 12, 2005
    8,549
    Laverton, Melbourne
    How does someone find out if work carried out is certified or not? do you get paperwork for certification? what if it gets lost?
  19. ewok85
    ewok85 Member
    Jul 4, 2002
    8,074
    Tokyo, Japan
    What you are/have done is no different to buying an electrical extension cable and run it through the wall.
    The answer would be that:
    Sankari
    Sankari Member
    Jun 13, 2009
    28,993
    Adelaide, SA
    Gotcha, thanks.
    Yep, that's right. Easy as! :D
    Thanks, this is all very informative. :)
    So the situation seems to be this: if I run a Cat5e cable through my house along the skirting board or the wall, or even up on the ceiling, that's legal. But if I run it through the roof, that's illegal. Correct? :wired:
    And if I want a legal roof installation, it has to be done with solid core, by someone who's qualified. Correct?
    Hard to see how a Cat5e cable could short out the power, since it's not connected to any power lines. :confused:
